Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Can I connect heat direct
MY central heating thermostat is not working. the wires are green, yellow, white, red and blue. can i connect anytwo wires for heating to be turn on for tonight.
  • virtualbest Jan 25, 2009
    Thanks. i have electric heating . I tried. first i connected red and white. but no fan. then added green. fan came on. but after waiting 10 min. there is no heat. just normal room temp air is coming out.
    could it possibly a heating system problem rather then thermostat problem. .
    the only wire left is yellow one.
  • 700 Answers
Yes if you have gas heat use r and w, if you have electric heat try that (R-W) FIRST AND IF THE FAN DOES NOT COME ON THEN ADD G. good luck
Posted on Jan 25, 2009
  • Todd Born
    Todd Born Jan 25, 2009
    you apparently don't have a heat pump because of the number of wires that you have. your right abiut the fact that after 10 nminutes you still did not have heat, it could be a limit thats bad or a sequencer that went bad. yoiu are going to need a service techniocian to do the repair for you.
I am wiring a honeywell thermostat model number ct87n if I select fan on the fan runs when out on auto /heat nothing but if I put on auto / cool and adjust the dial to a low setting the hea comes on....
there is it all depends on how many strands of wire are in there, they start at 2 wire and go to i think 8 wire and maybe more.
The wires are as follows:
1. red = power to stat.
2. green = fan control
3. blue or yellow = ac
4. white = heat
w1 = 1st. stage heat
w2 = 2nd. stage heat.
i am on line if you have any questions. wally
Feb 22, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I have 5 wires red,white,green,blue and yellow, but i dont now how to instale those cables please show mi how do it.thank you
This is if you have gas furnace and central air conditioning.
Normally this is the way.
Red wire to R (or if your stat has Rc and Rh, wire to both of these
White wire to W
Green wire to G
Yellow wire to Y
Blue wire to C
If you want to check, before you connect to stat. Connect red and white (heat should come on)
the connect red and green (blower should come on) Normally yellow is for air conditioning and Blue is common DO NOT CONNECT ANY WIRE DIRECTLY TO BLUE, if blue is common it would short out fuse
Jan 26, 2011 | Heating & Cooling
I have a digital Total Line thermostat that has a blue, white, yellow, red and green wire. Where do I attach these wires to the Model 44300A unit?
Normally Red to R (24v coming to stat) White to W (Heat) Green to G (Blower)
Yellow to Y (Air conditioning) Blue to C (common)
This is assuming you have gas heat and central air conditioning. If you have a heat pump blue would be for that. If you have a volt meter, check voltage between red and blue with furnace turned on. It will be 24 volts approx. if blue is common.
Jan 17, 2011 | Hunter 30124 Air Conditioner
The thermostat (I installed myself) is not working. I have no heat. It's a combination heat/ac. I read instructions. I'm thinking maybe I have a wire connected wrong. before I go any further, I'd like to...
Wiring color to Thermostat Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g. Hope this helps you. Thanks.
Jan 09, 2011 | Heating & Cooling
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
I need a wire diagram of a central heat and air with a heat pump
W- White (heat)
Y- Yellow (condenser)
G- Green (Indoor fan)
C- Blue (Common 24v)
R- Red (24VAC)
O/B (Only needed if system is a heat pump)
May 07, 2009 | Honeywell Heating & Cooling
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
