Question about Honda Heating & Cooling
96 accord ex 4cyl wont start battery new
Lights radio dash lts all work, car slicks when turn key to start but wont start
    New Friend:
Bang, on the starter with a hamer all around the casing,the brushes wear out and no longer make contact with the comutator will useually make them move as they are sping loaded, this is a temp fix and only good 4 a cple of weeks! u can change the starter 4 abt $100 bucks or pay $150+ 2 have it done! and ur gonna get a referb bad piece with a $50 buck core charge!!!rip off. what i do is buy the brushes from th auto pts store and replace them ur self abt 6 bucks abt 1 hrs work!
let me know if it worked 4 u!
Posted on Nov 24, 2013
1998 Accord will not start
starting withthe battery,check and clean ALL connections as something is not making proper contact.make sure the cables are good, clamps tight..work your way to the starter solenoid and check contacts/ connections there..also chech ground wires..all this is only if the battery does not have a shorted cell in it.. even new ones can get shorts..if you can get it to start go to autozone or advance..they do free testing..
Dec 22, 2013 | 2006 Honda Accord
Car turns over wont start no radio no dash lights its like key isnt on
Hi Chris, Check the battery and terminals. Try a jump start and if that works replace the battery. Regards John
Oct 26, 2012 | 2001 Ford Crown Victoria
I have92 Honda accord ex I can push start run great wont start with key new battery and new starter and fuses and relays what could be wrong
ignition switch is worn out its under dash on steering colum either install push button to start or replace also if its standard check clutch pedal sensor
Feb 16, 2012 | 1992 Honda Accord
My 2003 honda accord LX 4cyl vtech wont start. A few minutes ago the car is starting fine. Later, I put the key in the ignition and turn the key to start the car but it wont; the car doesnt make a noise,...
Make sure that the Shifter is in neutral or park. If that doesn't help, check the fuse and relay indicated for you started in the fues panel.
Jun 13, 2011 | 2003 Honda Accord
I have a 96 Honda Accord EX. Key on all dash lights come on. Turn the key to start and no response. What do I need to look for? Battery checks OK
Have you cleaned the battery terminals? You may also have a sticking starter selonoid. Tap it lightly with a screwdriver handle or small wooden mallet. If this doesn't work you may have to replace the starter after cleaning all the starter connections. It could also be the starter relay. Have it checked out first. Good luck!
May 18, 2010 | 1996 Honda Accord
96 Accord EX
Electrical short - probably
Mar 10, 2009 | 1986 Honda Accord
98 Honda Accord Wont Start
either have a shop scan it for trouble codes or buy a scanner your self at local parts store have OBDII scanner and find out for your self it could be a number of things.
Feb 24, 2009 | 1998 Honda Accord
1992 honda accord wagon lx 4cyl. battery good all lights, radio work when i turn the key on but when i try to start nothing, no noise nothing, can u help?
It's probably the starter or cable to the starter. If you can get to it check it with a voltmeter while someone turns the key to engage the starter motor. If you have 12volts DC and it doesn't turn it is the starter.Good luck...
Jan 19, 2009 | 1992 Honda Accord
Open Questions:
Heating & Cooling Logo
239 people viewed this question
Top Honda Heating & Cooling Experts
Thomas Perkins
Thomas Perkins
ray gallant
Jay Plesset
Are you a Honda Heating and Cooling Expert? Answer questions, earn points and help others
