GE S3700E4ww wont spin, and loud noise from motor area.
My washer motor caught on fire so i replaced it with a new one. I jumped the door switch to see if it would spin but it makes a LOUD buzzing noise like the brake is engaged and wont let it spin. I am including a link to a video of the machine. Please help.
http://www.youtube.com/watch?v=w20ppj6NEvs
  • 3 more comments
  • Deac Karns Jan 25, 2009
    here is the video
    The Capacitor seems to be fine. It is measuring 47µf just like the label says.
    What is the part number for the Bearing as shown on the GE print?
    That part is not in my washing machine. Can if fix the brake without replacing the transmission?
    what would I be checking the wiring for? what voltages should I see on what wires?
We had the same problem and found it to be the water level switch that was interfering with the spin cycle.
Check out the following:
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Posted on Feb 05, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Check your spinning rod is not stuck if not check the motor, Is that mount properly which is help the rod to move.
Posted on Jan 25, 2009
  • yashan.co.in Jan 25, 2009
    i think there is only machanical fault nor electical or electonics.
    President:
  • 2,559 Answers
Hey,it is a 2 speed motor and sounds like both speeds are starting at the same time.(check the wiring)Also here is a link to the service manual if you need it.http://repair2000.com/Library/GE%20Top-Load%20Washer.pdf
  • 10,515 Answers
Transmission / Brake issue :)
If we talk about noise, usually it is coz of transmission :0
However, as i have seen this video, more likely its coz of brake..
 Change the washer brake.
 The link to purchase tht part wld be :)
http://www.repairclinic.com/SSPartDetail.aspx?PartID=81&PPStack=1
Thanks.
  • taran_2005
    taran_2005 Jan 25, 2009
    Do you have the updated motor, harness and start cap? If it goes into spin and does this chunk a chunka chunka bit. Take a meter to the white and white/red wire going to the motor. If you have a steady 120V, replace the motor with the new kit. What the motor is doing is jogging between high to low speed. .taran_2005..post back.
  • 153 Answers
The baring must hav been ruiened first check it if ruiened replace it
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your description of the motor indicates that most likely the capacitor is faulty. This would be in the controls and backsplash area and marked part 217 in this exploded parts diagram.
Good luck and thank you for using FixYa.
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Entering test mode
1) try to go the instr. manual and go to the section troubleshooting they explain this . However if you do not have it download from .
www.manualslib.com
see this causes and fix it.God bless you
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch Assembly If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drain Pump If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Sep 30, 2012 | Washing Machines
Washer motor makes lots of noise as its trying to spin. Hardly spins at all with wet load. Spins slowly and still makes noise when spinning with drum empty. Does this mean the motor is bad or is it the...
If it is a really loud noise that drives you out of the house then probably a bad bearing. If that is the case then time for a new machine. Also check for something caught between the tubs.
Dec 02, 2010 | Maytag MAH6700AWW Neptune Front-Load...
GE S3700E4WW DOES NOT FILL AND SPIN. I HEAR LIKE IT WANTS TO SPIN BUT DOSNT SPIN OR FILL.
It sounds like the complaint of the units board which is located beneath the unit. You may take it out from the unit, but it can be repaired only by a professional. Sometimes, it should be replaced which may seem costly.
Aug 07, 2010 | GE WBB4500EWW Top Load Washer
GE/Whirlpool Duet electric dryer squeals badly... what is it and how do I fix it?
A common problem with noises from washing machines and dryers has been the under wire that may come out of a bra. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! In dryers, they can get caught in one of the drum seals and make a scrapping noise, (remove power, grab a flash light and have a peek inside through the door opening) or the wire can actually pass through one of the heating duct holes at the back of the drum and touch something electrical like the heating element, thermostats. If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Mar 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
May 07, 2009 | Whirlpool Inglis IP4400 Washer
My washer does not spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 01, 2009 | GE Profile WPRE6100G Top Load Washer
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
