Question about Brother IntelliFax-2820 Laser Fax
How to clean intellifax 2820 - Brother IntelliFax-2820 Laser Fax
  • 120 Answers
SOURCE: brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Posted on Apr 23, 2008
leroyal
  • 2120 Answers
SOURCE: Brother IntelliFax-2820
What is your email address?
Posted on Oct 01, 2008
  • 158 Answers
SOURCE: I have an Intellifax 2820
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Posted on Nov 26, 2008
  • 37 Answers
SOURCE: Time Change on Brother 2820
1.Press menu
2.Press 0
3.Press 2
4.Enter the last two digits of the year on the
dial pad, and then press Set.
5.Enter the two digits for the month on the dial
6.Enter the two digits for the day on the dial
7.Enter the time in 24-hour format on the dial
8.Press Stop/Exit.
Posted on Mar 02, 2009
shannongreer
  • 75 Answers
SOURCE: HOW do i get my brother intellifax 2820 to time stamp the faxe
From everything that I've seen I don't see any way to tim stamp incoming faxes. Almost all fax machines should automatically time stamp outgoing faxes unless the user has removed that function for some reason. If you are getting faxes from people that don't include time stamps than the next best thing is to use the journaling feature. The 2820 can print a journal of past incoming faxes that will include timestamps of the past faxes recieved in either 6,12,24 hour or 2, 7 day intervals. The default is every 50 faxes. To change the settings:
Press Menu/Set, 2,4,2
2. Journal Period
Use Arrows to choose an interval
Press Menu/Set
Press Stop/Exit
Posted on Jun 22, 2009
I'd like to turn off ECM on my intellifax 2820
There is no option to turn off the ECM on Brother Intellifax 2820 , just set the compatibility to Basic so that the ECM feature will not be available. Just press Menu 201. Press down or up arrow key to select Basic.Press Menu/set and then Stop/exit.
Hope this helps. Rate if it works. Thanks
Apr 13, 2011 | Brother IntelliFax-2820 Laser Fax
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
May 16, 2010 | Brother IntelliFax-2820 Laser Fax
REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Fax 2820 will not print. pages are blank
what do you mean printing stage?for the blank pages,it may only require cleaning.check the toner save setting,make sure it is off.clean the scanner glass of the machine,or you may just need to replace the drum
Nov 15, 2008 | Brother IntelliFax-2820 Laser Fax
Intellifax 2820?
Yes it can.But if you do manual faxing it only fax one by one.
Oct 29, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820 Says clear scanner jam and press stop
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
47 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
