Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa C250- accidentally formatted using MAC
I accidentally formatted the Sansa C250 using MAC. How do I restore the orininal software using Windows or MAC I have the original CD
  • Rajagopal Srin Jul 20, 2007
    I will try. I am not able to see this device using Windows disk mgmt or MAC Disk devices
    Thanks for your help
  • vgershik May 11, 2010
    I connected my mp3 player to the MAC that ate my files but when I did, the computer did not find the mp3 player drive when i went through the utilities method posted above. what do i do if apple does not recognize the mp3player? thanks!
    Scholar:
  • 155 Answers
Dunno if this helps.But we could try. Connect your player to the mac computer.Then double click the Macintosh drive. Click on Applications then click on utilities. Click on disk utilities and on the left side you will see the drives connected to the computer.Locate the mp3 player drive and highlight it then click on ERASE then choose MS-Dos file system to format the player back to a ms-dos file system.
Posted on Jul 22, 2007
  • 45 Answers
ITS RELATIVELY DIFFICULT TO REFORMAT THE DEVICE NOW INSTALL THE SOFTWARE FULLY INTO AN WINDOS OS THEN CLICK OPEN THE EXPLORING TOOL FOR YOU MP3 PLAYER WHICH IS BUNDLED UP ON YOU SOFTWARE CD AND LOOK FOR ANY BUTTON SHOWING BROWSE MY PLAYER AND CHECK FOR THE INITIALIZE OR FORMAT PLAYER UTTON THIS WILL DO THE TRICK ONE QUESTION TO CAN YOU STILL COPY FILES TO THE PLAYER
Posted on Jul 20, 2007
SOURCE:
How do you convert photos at windows media center onto your sansa c250
Use the supplied Sansa Media Converter program to convert your photos (and videos) to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
Jul 27, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
We just received a Sansa c250 MP3 player and we're wondering if we can use it on our Macintosh computer. It looks like the package says that Windows XP is required, but it doesn't mention if it will work...
You can. Just make sure you put the USB into MSC mode, so the Mac will see it. You can just copy files to it with Finder and use it like any other MP3 device. Also eject it before you remove it from the Mac. For MSC mode go into the menu and go to Settings and then select USB and finally select MSC.
Dec 27, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Drivers for sansa c250
You can't plug the same mp3 player into a MAC and a PC - one erases the formatting of the other. Run the Sansa Recovery Tool for the c200 series - it is available from the Sandisk website. Also, here is a link to the full user manual:
http://www.sandisk.com/Assets/File/Downloads/user-guides/c200-ug-eng.pdf
-Tha Mp3 Doctor
Dec 11, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I bought a 4gb Sanadisk microSDHC card for my Sansa c250 and Media player is not reading the card?
You must find the Sansa c250 menu that allows you to format the microSDHC card for use with media player.  Most microSDHC  cards are shipped unformatted.  It is a new technology and there is no standard format for microSDHC cards as they are used to store many types of data.  My cell phone uses one to store music, video,and photos, so the phone's manufacturer included a format command choice in the appropriate "phone memory" menu.  Look for the microSDHC card in a "memory" menu. Follow the prompts to format the card.  This only works on a NEW card.  If you format a used card, ALL data will be lost.  Formatting a card or a hard disk effectively prepares the memory to be written on, erasing any data previously written on it.
Sansa c250 and rhapsody
I first suggest that you use Windows Media Player on transferring songs to the player. Rhapsody is a p**n in the a** when i use it to transfer songs to the player. Well back to the topic, make sure the device that you have is set to MTP when you are transferring songs to the player using rhapsody.. If it will not transfer format the player using Settings and then FORMAT if it did not work format the player in MSC mode. To do this, go to settings then to USB MODE then change it to MSC and then connect the player to the computer. After connecting the player to the computer ti will be detected as a removable disk drive. Right click on it then choose FORMAT make sure the file system is FAT32. THen after the format is done. Chnage the mode back to MTP then transfer a song using rhapsody. If all else fails using the windows mediaplayer program. Here are the instructions on using the windows media player program.
http://www.sandisk.com/Retail/Default.aspx?CatID=1468
Aug 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk fuze 4 gig
There isn't software, because the software is not Mac-compatible. Sorry.
Jul 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa C250
Mine froze up and I just took the battery out. Then it stopped freezing up.
Mar 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I cant format my sansa c250 mpe
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 18, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250
if you have installed software cd that is given with the player you can format it in the browser along with it before formattin do nt foret to back up the contents in it
Jun 11, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
294 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
