Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Master spa lf code - Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Hot tub flashing LF what does this mean
LF (or FL) usually means there is a water flow problem through the inline heater. If there is not enough water in the heater tube, sensors prevent the heater from coming on - so that it doesn't burn out. Depending on your spa, you could have an issue with the filter or your pump may not be operating properly. There are also two sensors, one at each end of the heater tube, that could be malfunctioning. Did you drain and refill the spa recently? If so, you could also have an air block.
Dec 22, 2014 | Washing Machines
Brakes only working on one side
generally this means the pins need lubed up. however, I ran into this problem with another vehicle. Make sure that the bleeding proceedure is right. Not all vehicles are rr, lr, rf, lf. Also make sure you bleed the master. The final result of the vehicle I was working on was replacing the master, bleeding lr, rf, rr, lf.
Apr 14, 2013 | 1995 Buick Riviera
My pumps will not turn on. i have a ms501s balboa master spa. i checked the pumps and they worked good. but the control panel wont turn them on. what can i do?
Is there a message code on the spaside control panel? That would be important to know. If you see no error codes, chances are that you have 'dead' buttons on the panel, especially if you have tested the pumps via an other power source.
Jan 14, 2013 | Balboa Instruments Master Spas Copper...
My leisurerite spa pool is not heating up. It is displying LF
"LF" looks like "Low Flow" first thing I check is skimmer basket & filter to make sure thre are is nothing obstructing the flow
Sep 03, 2010 | Pool & Spa
Getting code 6000
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board or Paper Feed Motor or Paper Feed Roller Unit
May 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
26 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
