Question about Bosch Washing Machines
Bosch Washing Machine model WFG2460 drum doesn't turn
Everything else seems to work (including pump) I was wondering of the startup capcitor or the bushings on the spin motor is faulty.
Please Advise
Thank you
  • info581 Mar 20, 2009
    Your post answered my question and resolved my problem, how do I close this call and mark it as "Successfull"
  • Bosch Master
  • 3,463 Answers
There is no start capacitor on this washer if it has brushes in the motor, most likely the prob is due to worn brushes, to check them, do the following.
Remove rear panel, remove belt, remove motor plug.
Undo 2 screws securing motor, lever motor back with a screw driver or similar, keeping hold of motor and remove motor,.
You will find the brushes at the opp end to the motor pulley, replace if less than 1cm in length.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
Bosch Nexxt washing machine xxtra sanitary cycle does not seem to want to end anyone know how to fix this?
please check you water outlet pipe there may be some button or other debris in the pump preventing the water pump from emptying the drum eric
Dec 26, 2017 | Bosch Washing Machines
Bosch wfk 2800 drum makes a noise when turned around
When you rotate the drum by hand slowly does it feel bumpy and still make a noise? If so suspect the bearings on the drum to be the culprit. Hope this helps.
Nov 17, 2013 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Bosch WFLI2440GB/5 Washing Machine drain pump running continuously
Bosch WFLI2440GB/5 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 08, 2011 | Washing Machines
My bosch maxx stops mid cycle and the spiral icon that represents spin starts flashing. Its seems that it can not drain or spin yet the drum rotates when washing. Now i have washing stuck and i can not...
This is almost certainly a simple problem with your empty pump filter being clogged. Without knowing the model I can't be certain, but I would suggest that the empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
In the event that this doesn't work and you just want to get your washing out, you will find that turning the machine off at the wall for 20 minutes will reset it and allow you to open the door (With the power still off). IF THERE IS WATER ABOVE THE LEVEL OF THE BOTTOM OF THE DOOR, then pull the machine out and (With some help, because it's heavy!) Tip the machine backwards at about a 45 degree angle, so that the water line falls below the door before you open it.
If the above doesn
Aug 12, 2011 | Bosch Washing Machines
I get a gravelly sound from my bosch wfd2473 washing machine, mid way through the cycle,the drum seems to work ok, would it be the pump making the noise or is there a test i can do.
bosch wfd2473 washing machine This video will show you how to change the pump washing machine
Aug 02, 2011 | Bosch WFL 2063 Front Load Washer
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Dec 21, 2010 | Washing Machines
Bosch Exxcel 1200 Express Washing Machine spin not working
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Nov 09, 2008 | Bosch Washing Machines
Bosch wff 2000 washing machine - won't spin/drain
How did you solve this problem. I have the same problem. Kiran
Mar 09, 2008 | Washing Machines
Washing Machines Logo
133 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
