Question about Kenmore 73952 Gas Dryer
R kenmore gas dryer replaced igniter still no heat
Kenmore gas dryer runs great no heat. replaced the igniter and still no heat.
TRY REPLACING THE LITTLE BLACK OR WHITE TEMP SENSORS THEY LOOK LIKE A LITTLE BUTTON WITH WIRES GOING TO THEM AND THEY ARE SCREWED IN TO THE THERMOSTAT AND AROUND THE BLOWER YOU CAN TAKE THEM TO YOUR LOCAL PLUMBING AND ELECTRIC SUPPLY STORE AND THEY CAN TEST THEM THATS WHAT THEY DID FOR ME AND GOT MINE FIXED FOR 25.00
Posted on Jan 25, 2009
Kenmore gas dryer 80 series runs but, will not heat. Should I replace the igniter if there is no light seen when lower panel is off and the dryer is running?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore 63942 Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
My dryer runs but does not heat Kenmore 110.74722400
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 05, 2009 | Kenmore Dryers
Kenmore gas dryer wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 11, 2009 | Kenmore 73952 Gas Dryer
My kenmore gas dryer is not heating.I have taken apart and cleaned the lint trap as well as run a shop vac through the vent.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 17, 2009 | Kenmore Dryers
Kenmore Gas Dryer runs no heat were do I Start first
Check the following to address your issue. check each section of the dryer thoroughly.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 15, 2009 | Kenmore 74602 Gas Dryer
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Kenmore 72062 Gas Dryer
THE DRYER STOPPED PRODUCEING HEAT.
Check the following to address the non heating issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
My kenmore dryer is not heating
ck the igniter if it get hot red.if not .replace it.
Dec 18, 2007 | Kenmore 73952 Gas Dryer
Kenmore 73952 Gas Dryer Logo
155 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
