I want to uninstall deep freeze from my PC but am not able to find Deepfreeze icon on pc to disable it, kindly help to solve it. THanks
  • Anonymous Mar 14, 2014
    how to get deepfreeze activation code
  • 98 Answers
Go to your HDD and look in programfiles for the program uninstall or launch from hear
Posted on Jan 25, 2009
  • 29 Answers
Click on "start", then click "search" on the right. Type in "deep freeze" and click search. Windows will tell you where it's located or you can click on the search results (hi-lite) then right click and delete.
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
Dear sir i have a problem with my deep freez when i am doing the uninstall process the error has come " deep freez standard must be disabaled for any install/uninstall can proceed" plz help me...
Well, as it's said, you'll have to disable ("unfreeze") Deep Freeze before it could be uninstalled...
To do that, press SHIFT while double-clicking on the DeepFreeze icon on the notification area (near the system clock). Enter your password, and set it to be Thawed. Restart and re-do the unistall process.
If you don't remember the password, you can use DeepFreeze Unfreezer!
Good luck,
Pelu.
Dec 07, 2010 | Computers & Internet
How to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
Nov 24, 2010 | Computers & Internet
Yahoo.comHow to uninstall deep freeze 6 software from PC
Faronics Deep Freeze is a very powerful application, it prevents any unwanted changes on the system by freezing an entire hard disk or partition without restricting user access. Unlike older version, Deep Freeze 6 cannot be disabled or uninstall this Deep Freeze without password. Before u reformat or install a fresh OS, try the steps below, without password. 1. Boot yr PC from the CD with windows XP, if u have Windows XP OS 2. Now enter R to repair after booting. 3. Let it continue until finish 4. Now prepare the DeepFreeze to install, u will come across a option "Uninstall Deep Freeze", select this option and click next. After finishing the uninstall, reboot yr PC. 5. Now u will find that the Deep-freeze has removed from your computer.
Aug 25, 2010 | Computers & Internet
I forget the deep freez password and i want to uninstall deep freez but the dep freez are frozen. it is not disable
Oh!!
You have to Re Install your Operating System now. There Are no More Options left g\for your after forgot ting password. If you using license product then contact deepfreeze Devlopers to get help.
Thanks.
Happy to help you.
Apr 24, 2010 | Computers & Internet
How to uninstall deep freeze version 6.53.020.2763 ? i can't find the uninstaller for this program anywhere in my pc. thanks in advance.
source(http://tricks-collections.com/uninstall-deep-freeze-60-without-password/)
Smart Software for Deep Freeze v.6 to disable or uninstall this software in this time there is no. But with little tricks, Deep Freeze 6.0 can be disable or unintal not requiring password. following way to disable or unintal Deep Freeze ver 6 :
  1. Booting Computer From CD use Windows XP Installer
  2. After coming up with part to Enter Setup, Press Enter then F8 and await some moment
  3. then selected R to repair Windows ( Repair Setup)
  4. Hereinafter continue Install windows untill finish.
  5. Now prepare the Deepfreeze v.6 of and double click
  6. will appear “Uninstall Deepfreeze” windows and process uninstall till finish.
  7. Done……
Apr 21, 2010 | Computers & Internet
No deepfreeze icon in task bar
try to unfreeze it. then uninstall it by using your deepfreeze installer.
Jan 23, 2010 | HP Pavilion dv6000z Notebook
How to uninstall deepfreeze frm pc
Disable Deep Freeze before uninstalling it.
  1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
  3. If you have not yet entered a password you should be able to click OK without entering a password.
  4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
Deep Freeze is uninstalled and your computer is rebooted.
Let me know if this will help
Regards
Nov 27, 2009 | Cell Phones
Deepfreeze from my computer is not working properly
try uninstalling deepfreeze, it might solve your problem.. to uninstall deepfreeze, you must run the Installer file of deepfreeze..
Feb 03, 2009 | Ahead Software Nero 5.5 (NERO5.5) for PC
How to uninstall deep freeze from your pc?
To uninstall:
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
