My frigidare model (ATF6700FS1) reads error 23 and wont spin
  • Washing Mach... Master
  • 17,129 Answers
This is due to failure of the control board as the output to the drain pump is absent. This is due to failure or short of the drive in the circuit. or the drain pump relay
Posted on Jan 17, 2013
The CD player will rotate but won't play as though it's not reading.
How to Fix your CD Player ' Librarian in Black Blog - Sarah ...
librarianinblack.net/librarianinblack/how_to_fix_your/
Well, if I was a junk pack-rat and still had all the CD players I've thrown away because they stopped ... my portable cd player lens looks to be scarched how can i fix its ... my 3 disk memorex cd player won't play any thing. it was working fine and then allof a sudden it stopped on me it won't even spin the cd to try to read.
No Disc Error, not reading CD error: Repair Sony CFD 112 ...
? 11:35
https://www.youtube.com/watch?v=iEG_u0ogjZI
Jul 23, 2013 - Uploaded by 1000uf
How to troubleshoot and repair CD player not reading disc, table of content (TOC), ... +DeathlyHall0w It's ...
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
If you move the boombox with the audio CD player will it slip, with this model? ... I cannot buy a new boom box ...
Why won't my disks spin? - GameFAQs
Dec 22, 2015 | Audio Players & Recorders
My frigidare (ATF6700FS1) reads error 23 it will not spin
Failure of the drain pump relay or associated circuit. IF the board is examined for any loose joints to the drain pump and confirmed then the solution is a replacement of the control board.
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
I have an Frigidaire Affinity Washer Model ATF6700FS1 got error code E41. Thinks the door is open. I tried unplugging the connectors to the door switch but nothing worked. What to do now?
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Front Load Frigidare washer bouncing on spin, very bad!!!
Hi, not sure if you have solve this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Hi, not sure if you have resolved this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Frigidaire model ltf2940ee0
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Stpe 6 Also access and save or print your : OWNERS GUIDE, TECK DATA, OPERATING INSTRUCTION, INSTALLATION INSTRUCTIONS and any other guides listed that are needed.
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for viewing and printing.
Thank you and good luck.
Jul 14, 2008 | Washing Machines
Wont start cycle
Stpe 6 Also access and save or print your : OWNERS GUIDE, and OPERATING INSTRUCTION, and any other guides listed that are needed.
Jun 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidare front load washer
check to make sure you have removed all the shipping braces
Mar 02, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
