Question about Toshiba TP50H50 50" Rear Projection Television
Toshiba TP48E50 red power light flashing
Picture was displaying convergence problem, found web info on that, changed IC's with exact replacements. Verified all fuses, resistors, solder connections etc. Now, nothing! It goes into protection mode and flashing red light. You do here two clicks and some speaker noise upong plugging in. Any advice?
    Problem Solver:
  • 7 Answers
Hello there well form my prior experiences and ive had many...i would suggest checking high voltage maybe the horizointol output or try checking the flyback for shorts...it is in the power suppy.......hope this helps..someitmes these sets have codes and the blinking light in the front panel may indicate the problem..see how many time it blinks in intervals and then see if you can check out the codes on the net....
Posted on Feb 04, 2009
Red convergance no longer working and in advanced convergance mode, the lines look like they were pulled off of a globe and placed on a flat surface as the further from center they are, the more they are...
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. Your symptom sounds like a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT’s in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Mar 29, 2010 | Mitsubishi WS-48313 48" Rear Projection...
Convergence problem???
yeppers..those chips are soldered(more like welded) into the board, and usually runs you around 300 to 400 buckos..
Mar 02, 2008 | Sony KP-65WS510 65" Rear Projection...
My picture looks like I'm watching a 3D movie. What to do?
This is failure of convergence out ICs in your TV.
Replace Convergence Out ICs to get correct picture.
If you are handy with electronics stuff repair and can solder parts in circuit board with proper tools, let me know to provide you part number info, or ask local tech to get it repair.
Thanks.
Jan 26, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Double and blurred print and blurred picture.
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem. But if the set fixes itself you will need to have it repaired as soon as possible if you wait too long there are several components that will fail in due time. If you want to repair it yourself or know someone that can solder components on the circuit board, you will need to re-solder the convergence IC’s. All you will need is some solder wick, a good 45W soldering iron, Acid free solder and some solder wick (this is for the clean-up of solder joints and cleaning up solder bridges.
With any Projection Television that has a damaged or interment convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Their site is
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
asnowman
Dec 04, 2009 | Televison & Video
Panasonic PT56HX41PF projection TV. Image blurred up, color halos around objects on screen. Convergence in set up mode cannot be adjusted to compensate.
Their site is
You can also try
asnowman
Nov 29, 2009 | Panasonic Televison & Video
The TV is blurry with Red and green lines showing
Your symptoms sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink2.gif. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
Their site is http://www.andrewselectronics.com/welcome.aspx
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
Sep 20, 2009 | Mitsubishi WS-65711 65" Rear Projection...
When doing Magic Focus on Hitachi 51SWX20B I get Error 3, and the Process Stops. I have a Hitachi 60SDX88BA that also has a blue semi circle at the top of the screen. I have run magic focus and it stops...
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
No picture, but red light on front comes on
If one your convergence IC's is bad then you will still see a picture but the colors will not line up, especially around the edges. I have never seen a Toshiba projection set completely lose the picture because of a defective convergence IC. If your vertical output IC has failed or cracked loose then that is exactly what you will see - no picture! The vertical output IC is usually on the same board as the convergence outputs which explains why it worked last time, even if the tech was not 100 percent accurate in knowing exactly what was wrong - he just changed everything. Resolder that vertical output IC and make sure it is getting power. If you still have no picture after that then have a qualified tech look at the set.
Jul 12, 2007 | Toshiba 46H84 46" Rear Projection...
Convergence Problem inSamsung HC-P4752W 47" Rear Projection
One of the convergence output IC's has burned out and needs to be replaced. If the IC opens up inside then it stops working without blowing any fuses or resistors. The IC should be replaced and the set realigned by someone with experience in convergence circuits.
Jun 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
217 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
