Television picture problems really high gamma and fuzzy image
I purchased an acoustic solutions televsion i turned it on and the picture will not tune in via the contrast brightness and sharpness options it just stays all high in gamma and strange colour
i have hosted pictures here:
http://img185.imageshack.us/my.php?image=img0038cw4.jpg
PLEASE HELP i only got this television yesterday through ebay
  • barnes_grant Jan 25, 2009
    yes i have tryed that i have tryed everything that is on the menu
    yes the menu does come up clear as anything i have no idea what is wrong :S is there anything else you could think of?
    thankyou for trying
  • Anonymous May 02, 2009
    i have the same problem with my 50" panasonic plasma. I have been using the term "solarization" to describe the picture. Been in the repair shop twice, so far have replaced the ss board, sc board, and the lvds cable, problem still comes back. unit is only 5 months old; 2 of which were spent in the shop.
  • 362 Answers
If you are able to see the menus try and reset back to factory default settings.
You may also want to try try different inputs and different signal source, dvd player, cable, game console.
Let me know how it goes and please rate this solution. Lone99star
Posted on Jan 25, 2009
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
How do I fix a fuzzy screen
A fuzzy television screen is generally not the fault of the game console itself, but of your television.
The Xbox 360 is an HD game console, and from personal experience, trying to render an hd image in 480i Standard Definition will cause it to look somewhat fuzzy regardless of the television.
Just to make sure it is not the Xbox, I would, if possible, suggest you try the 360 on another television, preferrably with the HD cables (remember that there's a switch on the cable itself that you will need to switch from SD to HD).
Unfortunately, if you do not have access to a high def television, you can always fiddle with the contrast and sharpness on your standard def TV to reduce the fuzzyness, but the screen will always be somewhat fuzzy.
I realize this is probably not the answer you wanted, but to solve this problem for my own Xbox, I ended up purchasing an inexpensive HD Television.
Nov 01, 2010 | Microsoft Xbox 360 Console
We just purchased an Samsung Plasma model #PN50B1D
unfortunately these newer tvs do not display the standard definition analog channels very well. the picture gets better when viewing digital channels but doesnt display at its best untill u place it on a high definition channel
Feb 07, 2010 | Televison & Video
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
Acoustic solutions lcd 22''tv turn it on then it turns it self of
Acoustic Solutions 32 lcd hd Tv screen has green/blue contrast shadows all over the light images on the screen. I have tried changing all the picture setting to no avail.
Aug 22, 2009 | Televison & Video
My Vizio 42in. is really fuzzy
If the picture is clear when using a DVD and remains "fuzzy" only with cable, then either the cable is bad or the up-conmvert from standard def to Hidef is creating the "fuzz". Depending upon the method used by the set to perform the "up-convert", the noise you are seeing may be normal.
Dan
Jan 27, 2009 | Vizio L37 Television
Fuzzy, cloudy pictures
As basic as it sounds, is the lens dirty? The tiny surfaces of digital cameras' lenses really affect image quality. Also check the image quality setting to ensure you're shooting at a high quality setting.
Dec 31, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
2 images
you have possibly 2 faults /one may be convergence ,the other is screen adjustment set to high(red).
Sep 06, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
Electro Med Services...
