Question about Datalogic Memor Wireless Barcode Scanner
Scanner not importing data - Datalogic Memor Wireless Barcode Scanner
How to reset a uniden bc346xt to factory settings iwould like to program my local police
Scanner Reset to initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on (It helps if you can lay it flat). The scanner will give you the option 'Restore Preprogram List? "Yes"=E/No="."', if you press 'E/Yes', the scanner reloads the preprogrammed systems. Important! This deletes all programmed data. Easier to Read BC346XT Scanner Manual
here is link to manual
Jul 19, 2017 | Uniden Radio Communications
O2 sensors showing no voltage on diagnostic scanner
What is most important here is what fault codes you have, I will work from that, as to the scanner I have no way to know if it is working correctly.
Oct 19, 2016 | Cars & Trucks
When diagnostic tool is connected,some data seems not to be correct,while engine not in run,throttle amount is 99%,while TPS is disconnected,also idle increase switch is disconnected but appear YES
What kind of vehicle, year is important if its a mid nineties car the switch from obd1 to obd2 took a couple years and not very accurate are you reading live data or freeze frame data
Apr 19, 2015 | Cars & Trucks
Reset my uniden ubc3500xlt
Scanner Reset: To initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on. Important! This deletes all preprogrammed data. You cannot restore preprogrammed data that has been deleted.
Jul 09, 2014 | Uniden UBC-3500XLT Handheld Scanner...
Hi i'm trying to find out is simply accounting and NeatDesk scanners are compatible. What i am looking for is a way to scan a invoice file and import the information into simply accounting with out...
There is no scanner invented yet which can create a file that can be read completely read by accounting software like excel because the file that is created is an image file whose individual data like numbers and alphabets could be read by the most up to date accounting system. The only solution I see is that a data entry operator has to manually enter the data in the computer system.
May 17, 2011 | Computers & Internet
I'm face problem about my pen drive which don't recognized any computer. But i've important data on that pen drive. I've need to solution to recover my important data from my problematic pen...
Unfortunately it seems that pen drive was poorly made and has physically broken.
There are services out there that will try to retrieve data from damaged media, but they are often expensive and not worth the cost.
Dec 20, 2010 | Computers & Internet
Using adobe photoshop 8 the editor will import from my Epson Perfection 1260, but the organiser will not get from it displaying "Epson perfection 1260 software for this device could not be launched the...
I don't think it's any of those things. I think it's a Twain Data Source problem. When you install the software for your scanner, make sure you also install the twain data source files. This is the scanning protocol used by all scanners and if not present, the scanner won't import images into Photoshop under the command "File" -> "Acquire."
Mar 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Feb 13, 2010 | Uniden BCD996T Base Scanner
Programming channels
Hello ... IF YOU HAVE A COMPUTER YOU CAN MAKE PROGREMING, DETETINMG AND TRUNKING A BREEZE. IF NOT I FOUND THAT ALL FIRE AND POLICE TRUNKING ACTIVITIES ARE BETWEEN 840.0000 through 900.0000. WHEN YOU WANT TO SAVE A CHANEL TURN OFF RADIO AND TURN BACK ON SELECT THE DESIRED CHANNEL YOU WANT. THEN PRESS "PGM" AND ENTER YOUR FREQERNCY... PRESS ENTER AND IF YOU WANT TO ADD ANOTHER CAHANNEL ... HIT "PGM" AGAIN AND FREQ. AND ENTER. YOU CAN KEEP DOING THIS TILL YOUR DONE GROGRAMING .. THEN JUST HIT SCAN AND IT WILL SCAN ALL THE FREQ.S YOU HAVE ENTERED. HERE IS A SOFTWARE PROGRAM THAT CAN LOOK UP ALL FRQ ANYWHERE IN THE US AND WITHE A PLUGIN DOWN LOAD ALL THE CHANNELS. BuTel software home page ARC-433 software for Radioshack PRO-433 / PRO-528 / PRO-2051 'ARC433 is now available!' -------------------------------------------------------------------------------- ARC433 (US$ 29.95) is dedicated software for the RadioShack PRO433, PRO528 and PRO-2051 and is the most versatile software available for the Radio-shack PRO-433 / PRO-528 / PRo-2051. Screenshot from our memory editor: the most versatile memory editor available on the market: -------------------------------------------------------------------------------- Overview of options in ARC433: Order ARC433 now online using PayPal/credit card or call Santa at 1-800-SCANNER ARC433 supports the Radioshack PRO433, PRO528 and PRO2051 models in one single software package. ARC433 includes THE most versatile memory editor available on the market. Radioreference.com import option for conventional and trunk systems! Programming your scanner was never this easy! Enhanced CSV file import and 'mapper' Paste Frequencies DIRECTLY from any website using 'Paste Special' Setup channels in an easy, spreadsheet type interface. User Manual (45 pages, PDF file) Store Unlimited number of configurations on your harddisk. Copy/Move/Swap memory banks / memory channels Compatible with Windows 2000 / XP. All updates are free for registered users Easy cut/copy/paste data between channels and banks. Move channels up and down with quick move buttons Export CSV data Fill down/series option Full clipboard support for import/export data to/from other applications Easy data toggle with mouse double click or space bar or keyboard shortcuts Sort frequencies per bank Remove duplicate frequencies Easy Fill for setting up new banks in a few seconds (enter a start frequency and a step, and easyfill will calculate and fill the selected bank) Extra Dummy bank for storing temporary data while you are re-organizing your scanner channels. Print option System Requirements: Windows XP/2000/Vista PC interface cable 20-047 for USB or PC interface cable 20-289 for serial port Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final. Order ARC433 for PRO 433 / 528 now online using PayPal or a credit card or call 1-800-SCANNER. -------------------------------------------------------------------------------- Screenshots:
Apr 16, 2007 | Radio Shack Pro-95 Handheld Scanner
Datalogic Memor Wireless Barcode Scanner Logo
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
