Panasonic na-168vg3 h51 code flashing
H 51 flashing what does it mean
    New Friend:
Hi Rick, What does H 51 mean on the display of my Panasonic NA 140vg3. However, after that code has flashed a circle symbol will appear, then it will disappear. The door won't open. I would appreciate your help. Cheers
Posted on May 24, 2015
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: washing maching not working
Hello would need the complete model number and the make of the machine to provide exact solution whereas Error code 51 for a kenmore elite, Calypso, Catalyst usually tends to point towards a defective rps sensor which is the small sensor located on the stator (motor ). I will await your reply in order to supply an exact diagnosis of your issue
Thank you
Rick
Posted on Nov 22, 2011
How to fix H51 error
Under the machines cabinet,there should be
a bag with a diagnostic manual, you can use
for the codes & troubleshooting problems
Nov 01, 2014 | Washing Machines
Air bag light flashes code 51.
If your airbag code is blinking, and you get 51, it means that your internal thermal fuse in your airbag computer is blown which is caused by an intermittant short to ground on one of the wires in the circuit. When the short to the ground is removed, code 51 flashes with the use of the airbag warning lamp, 5 flashes, pause, 1 flash, longer pause. According to the Ford, this is a nonrepairable fix, you must buy a new air bag module which is a blue box located in the vicinity of the the steering column.
Apr 10, 2014 | 1994 Ford F150 Styleside Supercab
Error h51 panasonic front loader washing machine 8kg
What happen the washing machine model NA-148VG3 show H57 mean what happen?
Jun 02, 2013 | Washing Machines
Washing maching not working
Thank you
Rick
Nov 22, 2011 | Washing Machines
Panasonic washing machine NA-168vg3 stopped with 31 mins to go giving error code U11
U11 is inability to drain. Check your filter. Check your outlet hose. If you can blow down it, then your pump's jammed. I just found headless metal rivet type pin in the pump. Take the drain flap off, and remove the screw. This whole width panel now moves off to the left.Lean the machine on it's side, take off the black plastic plate. Remove the two screws from either side of the filer on the front. Pump is now loose. Remove the three screws on each pump and check if anything is stuck in the impellers.
Refitting is the reverse.
I know this is an old post, but someone may find this useful!
May 18, 2011 | Microwave Ovens
How to do manual setting for Panasonic Washer NA-F701GS
I keep program to normal, water level 51 and wash,rinse & spin but half way the washing machine go to reserve button (9 hrs).
how do i cancel the reserve button?
Nov 28, 2010 | Panasonic Washing Machines
I have code 51 flashing. Where is the air bag diagnostic module located?
Hi, the code 51 flashing means that the internal fuse is blown and the short to ground is no longer present. If the short to ground returns, the code will change to 13 (air back circuit shorted to ground) or 14 (primary crash sensor circuit shorted to ground), but it will only flash 13 or 14 when the short is present. If the code remains 51, then first find and repair short before replacing the diagnostic monitor (what people call air bag module).
Take care
Aug 03, 2010 | 1994 Mercury Grand Marquis
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Flashes code "ddo"
ddo is Dispenser Drawer Open
Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing
Magnet is shown at location #51 on page two of this parts manual..
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995430112.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 08, 2009 | Washing Machines
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Washing Machines Logo
788 people viewed this question
Top Washing Machines Experts
