Question about Scientific Atlanta dpc2100 - Cable Modem W Power Supply
161-101 error code on cable box - Scientific Atlanta dpc2100 - Cable Modem W Power Supply
What does code Soaoo indicate?
Search Results
    S0A00 Set-Top Box Error Message Help - Comcast
    customer.xfinity.com/help-and-support/cable.../getting-error-code-s0a00...
    Learn what S0A00 on your Comcast cable box means and how to resolve this ... A number of signs can tell you if your computer may be infected with a bot, ...Missing: pioneer
    ref code S0a00 - Comcast Help and Support Forums
    forums.xfinity.com/t5/XfinityTV-and.../ref-code-S0a00/td-p/855021
    Jan 18, 2011 - If you getting S0A00 errors, that means you have signal issues, most ...fios is cheaper than comcast, can you give an example of how fios is ...Missing: pioneer
    Comcast Ref Code S0a00 - How Do I Fix It? - GeekDrop
Jan 23, 2016 | Pioneer Televison & Video
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Set-top box has encountered an error BE1
If you use a cable box, then either the cable box is putting out a signal that the set cannot understand or the set has a problem with one of the boards in it.
Nov 18, 2013 | Samsung Audio Players & Recorders
Removing regional code toshiba d-kr10
will it copy from another sorce? if the programing from your cable box is copy protected it will not let you record.
Feb 06, 2013 | Toshiba D-kr10 Dvd Recorder With 1080p...
First and foremost, DVD's still play perfectly and the colors are beautiful, perfect and alligned on my PT53WX52. However, on Regular TV-(Cox Cable) every human being appears to be the color similar to...
Replace the cable from your cable box to television. Try one from one of your other cable boxes before buying one, but I highly suspect the actual cable from box to TV is bad
Feb 24, 2011 | Panasonic PT-53WX52 53" Rear Projection...
Error code E 68
The error code and the statement that the cable company can't access the box indicates that either the box has a hard fault or the communication path has been corrupted. A hard fault would require your cable company to repair or replace the box. The communication path can be corrupted by failure of splitters, connectors or cables, which doesn't "just happen" often but is a possibility. It sounds like the cable drop to your house is split prior to entering the house, therefore, I would recommend inspecting that area to determine if the exposed cable/splitter has been tampered with or damaged. If there are other cable access points in the house, then there are other splitters that should be checked. BTW, have you tried plugging the cable directly into your set to see if the set's built-in NTSC/analog cable tuner can receive any signal? This could help rule in/out connectivity issues or 6200 stb failure.
Oct 01, 2010 | Arris DCT6200 DTV Receiver
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
My cable box has error code E607
scooters dont have cable boxes thats your tv
Nov 13, 2008 | 2004 Aprilia Scarabeo 200
Motorola 6412
There are no code modules on the box. The box is searching for the appropriate code to download and is not finding anything suitable. Time to call your cable company.
Dec 09, 2007 | Arris DCT6200 DTV Receiver
OE Error
Keep clicking on the "Tags" above, you are sure to come up with something useful........
Sep 15, 2007 | LG 24 in. LDF 7811 Stainless Steel...
Scientific Atlanta dpc2100 - Cable Modem W Power Supply Logo
26 people viewed this question
Top Scientific Atlanta Computers & Internet Experts
David Payne
David Payne
Are you a Scientific Atlanta Computer and Internet Expert? Answer questions, earn points and help others
