Question about Kodak EasyShare Z740 Digital Camera
Camera turns on then off
I have a Z740 for just over a year. This past week it started acting up. When you turn it on it immediatly turns itself off. Stays on in favorites mode. Kodak wants $135 to fix it. Any other ideas? Out of warranty in May.
    Genius:
  • 2,985 Answers
What will $135 plus a bit buy in the way of a new camera? This is a firmware problem- really Kodaks problem they should offer you a replacement camera for a little less than $135. Push them hard.
Posted on Jul 19, 2007
SOURCE:
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Camera turns off when you use telephoto lens camera turns off.
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Apr 21, 2010 | Kodak EasyShare Z740 Digital Camera
My z740 camera will not stay on
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
Mar 19, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak easyshare Z740 battery problem
I hope that helps.
Oct 22, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak z740 will not turn on
I hope that helps.
Mar 29, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak Z740
I hope that helps.
Jan 03, 2009 | Kodak EasyShare Z740 Digital Camera
I hope that helps.
Nov 05, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
