Question about Frigidaire ATF6000ES Front Load Washer
My frigidare (ATF6700FS1) reads error 23 it will not spin
  • Frigidaire Master
  • 17,129 Answers
Failure of the drain pump relay or associated circuit. IF the board is examined for any loose joints to the drain pump and confirmed then the solution is a replacement of the control board.
Posted on Jan 17, 2013
Spindle test Failed (Error code: WCD44-RVH)
Spindle usually refers to the spinning axis of the carbon disks or the platters. The disks are likely not spinning and a drive replacement is required.
Jun 25, 2014 | Dell Inspiron 530 Desktop Computer
My frigidare model (ATF6700FS1) reads error 23 and wont spin
This is due to failure of the control board as the output to the drain pump is absent. This is due to failure or short of the drive in the circuit. or the drain pump relay
Jan 17, 2013 | Washing Machines
I have an Frigidaire Affinity Washer Model ATF6700FS1 got error code E41. Thinks the door is open. I tried unplugging the connectors to the door switch but nothing worked. What to do now?
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Front Load Frigidare washer bouncing on spin, very bad!!!
Hi, not sure if you have solve this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Hi, not sure if you have resolved this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Dvd rOM BURNER HAS ERRORS
Try a new DVD ROM. They are very inexpensive.
Mar 23, 2017 | Computers & Internet
Frigidaire model ltf2940ee0
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Stpe 6 Also access and save or print your : OWNERS GUIDE, TECK DATA, OPERATING INSTRUCTION, INSTALLATION INSTRUCTIONS and any other guides listed that are needed.
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for viewing and printing.
Thank you and good luck.
Jul 14, 2008 | Washing Machines
Frigidare front load washer
check to make sure you have removed all the shipping braces
Mar 02, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
289 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
