Question about HP LaserJet 2820 Printer
I have an HP Laserjet 2820 which had a paper jam.  I cleared it and have reset it and it still says there's a jam.  Any advice?
    Genius:
  • 2,120 Answers
Have you looked in the rear of the printer at the FUSER unit? Flip the blue levers and the fuser will come out.
Posted on Jan 25, 2009
Hp laserjet 1005 printer second page paper jam
Hi senthil, my name is Lisa and I would be happy to help you with your Laserjet 1005. I understand you are experiencing a paper jam when printing multiple page documents.
There are multiple variations of the 1005, below I will list 3 links one for each of the 1005 Laserjet printers I think you could have.
Clearing Paper Jam for HP LaserJet P1005 P1006 P1007 P1008 and P1009...
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=1839458&docId=emr_na-c00765431&docLocale=en_US < HP LaserJet M1005 MFP - Clearing jams
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=bpl10965 < HP LaserJet 1000 Product Family - Clearing Printer Media Jams
I hope that one of these links is specific to your printer, and that the appropriate link helps you resolve the issue.
Best of luck. I work on behalf of HP.
Jul 02, 2015 | HP Office Equipment & Supplies
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
HP paper ajm
Go To Below official HP Printer Page For Your problem, Clearing Paper Jam Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet P2015n Printer
HP LASERJET 100 COLOR MFP M175a PAPER JAM
I suggest you some points like clear the dust in the printer, proper set paper in paper place, adjust the paper line etc..
If More Support visit this link. I hope solved you problem..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02622145&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=5076465
Jan 15, 2014 | HP LaserJet Pro 100 color MFP M175A Laser...
I have an hp colour laserjet 2820 printer and it tells me there is a jam in the paper path. i have taken out every carteridge that I possibly can and opened every door that can possibly open and there is...
this error its tricky. You need to take out the fuser (in the back there are two blue locks) and inside the printer in the center of the paper path you will find a black plastick stick. Its a sensor for the paper path that did not went back to the regular position. Its dificult to explain, but if you can find it the issue will be solved 100% sure
Sep 07, 2010 | HP LaserJet 2820 Printer
My printer jammed while trying to fax a legal document. It said to clear the feeder, which I did, by lifting the cover and pulling the document through. It continues to give the error message that there is...
Here's what I think you need to do. 1 Open the top cover. 2 You will see a roller assembly. 3 rotate the assy up so its pointing up. 4 Remove the spring. 5 the roller assy will now lift out. (note how it came out.) 6 you will now see a green piece of plastic on the left. 7 Remove the green plastic and see if any paper is there. (note how the green piece came out.) 8 Re assemble and test. Thank you, Steven 805-520-3003
Jul 26, 2010 | HP LaserJet 2820 Printer
HP laserjet 4650 with 'phantom' paper jam
hi , I had similar problem,the printer memory is locked on that last transaction feed,
either. check all copy transactions are deleted.you may not reolise you have 3 or 4 still programmed for shedule.
un-install the printer from your pc
the re-install shuld clear it.
set - printer to default mode
you may find your printer works fine on a friends pc, try all or either of above good luck colin leeds
Jul 16, 2009 | HP Color LaserJet 4650DTN Printer
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
Paper jammed and now will not turn on
Pull out the laser cart and see if you can locate a sheet from that end.
May 31, 2009 | HP LaserJet 2840 Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
HP LaserJet 2820 Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
