Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore Oven Stuck on Clean
Used the clean cycle to clean. Door will open but when you turn the oven on the "clean" light blinks and the preheat or oven on lights do not come on. Have unplugged...plugged back in...same thing.
Any suggestions? Can't find a model number and do not have the owners manual. The clock is digital if that helps any!
  • 979 Answers
You could possibly have a bad control switch. But first check all wiring from the receptacle, plug (wires all connected), wiring to the back of the oven. I am hoping that their is not a bad circuit board.
Posted on Jan 31, 2009
How do I fix an oven lock on a self cleaning Kenmore built in dual ovens? The oven locked up during a clean oven cycle and will not unlock.
Some ovens will not open unless the clean button or knob is set to Clean. Make sure you are trying to open in correct direction. Try turning it on and off and press down on the latch while trying to open. I would not use a crow bar, this can be done. If you unplug it and wait for it to reset after about 30 seconds it might let go. Just keep playing mine stuck once and it was because I flipped the clean switch off an turning it back on ready to start the cycle pulled back on it and it opened. Oh I remember my neighbor had a older style dial clock and she set the clock for a certain time to stop and the door would not open until she ran the clock to that time spot. Hope this helps. I wish I knew how to open it from the electrical side but I dont.
Jan 30, 2015 | Kenmore Ovens
Oven is model 665.95781. I used the cleaning cycle.Oven door will not open. Message is E1 F5. Please help!
Based on your description, the E1 F5 error code likely indicates that the door latch is not operating.
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
Mar 20, 2011 | Kenmore Ovens
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Older oven stuck on Clean and door is locked.
does your oven have a lift up top if does. lift up burns and silver box open box and you can unlatch the lock. hope workds
Apr 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How can i quit cleaning oven?
During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Smoking Kenmore
Hello oliver909
Welcome,
You said,Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
If your afraid to use it, do not hesitate to call service. Nobody wants a fire!
Huuum
Oct 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Locked oven door
try turning off the circuit breaker, resetting the power sometimes trips the self clean latch to operate, youll need to push in the door light switch.(it will have to think the door is closed to operate)
Mar 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
135 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
