Question about KitchenAid 20.3 cu.ft. Counter-Depth Bottom Freezer Refrigerator
Water is dripping from my water dispenser and I can't stop it
I need to know how to stop the leak
    President:
  • KitchenAid Master
  • 2,651 Answers
Usually it leaks becasue of air trapped in the line, did you just replace the filter ?? or oso to a new installation??? if so try holding the button in for a few min( a large picher full) to clear any trapped air in the line
Posted on Jan 25, 2009
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
The water keeps dripping from the water dispenser how do I get it to stop
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jan 23, 2011 | Refrigerators
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
The water dispenser will sometimes drip and doesn't stop. It doesn't stop by pulling forward on the lever, I have to push it in as though I'm dispensing more water and that usually stops it. If I don't...
There may be several reasons for this like a leaking water control valve, air in water lines or you may just need to replace the dispenser water line with a kit Part Number 8201537 Try unplugging the dispenser power on rear of refrigerator and tell me if that stops the flow. let me know, Sea Breeze
Apr 20, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Our Kenmore side by side model number 10653382300 is having a problem with the water/ice dispenser. The water dispenser continues to drip and I can not get it to stop. How can I fix this problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jan 08, 2010 | Refrigerators
TFC27ZFS GE frig will dispense water then continue to leak water and doesn't stop?
Sep 24, 2009 | Refrigerators
My Whirlpool refrigerator also leaks water from back.
Leaky dispenser ???
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. If so you need to replace the valves.
Aug 20, 2009 | Refrigerators
Built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
appliancepartsoutheast@live.com
Aug 10, 2009 | Maytag Refrigerators
Water leaking from water dispenser
replace your water valves one for the door disp is leaking
Feb 16, 2008 | Whirlpool ED5FHEXMQ Side by Side...
lot of water coming from under the refrijerator
Jan 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
KitchenAid 20.3 cu.ft. Counter-Depth Bottom Freezer Refrigerator Logo
105 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
