Question about Sylvania 202SL8 TV
Green Outline.... I get a green outline whenever I look at Black Text on my info screen, and I also noticed when watching family guy that the characters had a green outline as well, I tried adjusting the colors and everything else, but it did not work. Is there anyway of fixing this without having to take it to a repair shop?
    Problem Solver:
  • 5 Answers
THERE IS NO WAY YOU CAN FIX IT WITHOUT SENDING IT TO THE REPAIR SHOP BUT IF YOU ARE A DIY PERSON YOU MIGHT BE ABLE TO FIX IT- ON THE NECK OF THE TUBE THERE IS MAGNETIC RINGS WHICH MUST BE ADJUSTED THE PROCEDURE IS CALLED CONVERGENCE WHICH IS NORMALLY CARRIED OUT BY SERVICE TECHNICIANS
Posted on Jul 15, 2007
SOURCE:
Picture has a red shadow. especially
Convergence problem on rear projection CRT TVs.
Apr 19, 2010 | Televison & Video
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
Vizio - green outline
Call for Waranty service,video backlight have prob.is dying.
Oct 04, 2009 | Sony KLV-S26A10 26 in. HD-Ready LCD...
Green outline/shadow on dark images or backgrounds
LVDS Cable is corroded - This is the cable the provides video from the TV Video Process board to the LCD Panels Timing Control Board.
Honestly, if you can take the TV back do so. If not, Service it using the manufacturer warranty
Jun 24, 2009 | Vizio Televison & Video
Green outline really noticable around white objects like golf bal
Almost certainly you need the convergence IC's replaced. This is a big job you cannot do yourself.
Mar 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Green, red, and blue lights don't line up on screen
hi you have faulty convergance ic also there may be some faulty resistor and capacitors that sit in front of the ic, thanks
shaun
Jun 27, 2017 | Hitachi 50SBX78B 50" Rear Projection...
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Sylvania 202SL8 TV Logo
65 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
