Question about Gigabyte GM-ECO600 Wireless Laser Mouse
Gigabyte GM-ECO600 Wireless mouse stops working intermitently
Mouse works intermitently
Get new mouse.. Don't buy 10$ mouse.. Spend $15 or more.. Big difference in life.. Usually..
Nov 22, 2013 | Kensington Technology Group Kensington...
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
How do I change batteries in gigaware mouse
you will found small button in the bottom use it to open
Mar 26, 2011 | Ultra Max Gigaware Wireless Laser Mouse
My model is GM-M7700B. My computer recognizes the mouse but cannot connect to it. I have the device could not be connected dialbox all the time. When I go to View my devices it is there, Gygabite HID......
I had the same problem and finally i solved it. I don't have English Windows (Win7) so some phrases could be inaccurate.
1) When the mouse is found in the Add Device Dialog, use your touchpad or keyboard (use TAB and arrows to select and SHIFT F10 shortcut for rightclick) to rightclick on the device image and hit properties.
2) Tick "Drivers for keyboard or mouse (HID)" and then press apply and ok. Driver will be updated and your mouse should work now.
I hope this will help you, bye Vlada
Aug 25, 2010 | Gigabyte Wireless Optical USB Mouse GMW7C
Mouse suddenly stopped working
1: Make sure the battery or batteries in your mouse are good.
2: If there is a USB dongle plugged into a USB port on your computer, unplug it, wait 3 or 4 seconds and plug it back in.
3: If the above two steps don't work, shut down your computer completely and start it back up again.
Your problem should be solved:
USB dongle
Sep 21, 2017 | Gigabyte GMW9CRD Mouse
I believe that you need to change your batteries on your mouse. If that doesn't helped and it is still in warranty try to turn it back from where you bought it and ask for repair or replace. Hope that helped!
Mar 22, 2010 | Gigabyte GMW9CRD Mouse
I have a gigabyte wireless mouse, and have charged the batteries and tried to sync the mouse, but nothing is happening
Look in device manager and see if it recognizes the device.. should appear as a human interface device and under the mouses. If not then unplug the mouse from the usb port and plug it back in. If it still doesn't recognize the device then search for new hardware or find a driver on the internet.
Jul 29, 2009 | Gigabyte GMW9CRD Mouse
My dell wireless mouse works intermittingly. Starts skipping and then works for a while. Changed battery and cleaned mousepad no improvement.
At the back of the Mouse, there will be small flushed 'reset' button. Press that. It resets and reconfigures the connection.
Have a nice day :)
Jun 11, 2009 | Logitech Wireless Access Duo Optical...
IBM mouse stops working intermitently
replace mouse with a ps2 model instead of usb
Apr 14, 2008 | IBM 06P4069 Mouse
Right mouse button, wireless intellimouse explorer 2.0
the right and left buttons are controlled by a switch you need to replace the switch
Dec 07, 2007 | Microsoft Wireless IntelliMouse Explorer
Open Questions:
Gigabyte GM-ECO600 Wireless Laser Mouse Logo
368 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
