Question about Refrigerators
Water leaking from freezer / above refrigerator section, ice maker not leaking, could this be from the defrost cycle?
    President:
  • Refrigerators Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Jan 25, 2009
Water leaking from bottom of freezer
Its defrost issue.The refrigerator is not defrosting on time,its defrost cycle is running late causing these problem.
Can be faulty defrost system parts or issue with defrost timer.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | General Electric GSH22JFX Side by Side...
Water leaks inside refrigertor
The defrost cycle is not taking place.The cooling cycle runs and then defrost cycle starts.But its not working in your case.
Try reset:--
Unplug unit from power outlet for 12 hours,then reconnect and see it helps or not.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
My icemaker is not working.
Hi and welcome to FixYa, I am Kelly.
Often when ice makers slow production or stop making ice it is because the freezer compartmet\nt has warmed up above 17 Def F and the ice maker thermostat will not cycle to start the ice harvest cycle.
In the back of your unit you will have an inlet water valve assembly that will look similar to this one:
Water Dispenser Not Working Check the water supply to the water inlet valve. Check the water filter. ( if applicable)
Check the water inlet valve
Make sure the Temperatures in the Fresh? food section and the freezer sections are normal. 33 to 42 in the Fresh Food section and 0 to 10 in the freezer. Or check that the controls, both the fresh food and freezer section controls are set on the "normal" settings. If the controls are set too cold it will cause the water? tank or tubing to freeze.
Dispenser switch not? working, check for continuity
One side of this valve does the water in the door, the other the water for the ice maker
Disregard any reference to water in door if your unit does not have that capability and there will only be ONE solenoid on the inlet water valve assembly.
If the solenoid coil fails it will not open the water source to supply water to the ice maker. This solenoid is only energized for 8 to 10 seconds as the ice maker sweep fingers (Called ejector blades in the manual) reach the 10 - 11 o'clock position during the harvest cycle. All you will hear is a minor buzz and maybe a minor thump of the plastic water line but the ice maker fills during the last 40 % of the harvest cycle.
Here is a manual you can use for troubleshooting:
Kitchenaid-Estate%20Appliances/Refrigerator/In%20Door%20Ice%20Manual%20with%20Diagram.pdf">http://www.affordableappliance.com/Download%20Folder/Whirlpool-Roper-Kitchenaid-Estate%20Appliances/Refrigerator/In%20Door%20Ice%20Manual%20with%20Diagram.pdf
Note the requirements to test the ice maker using the manual above are:
Door light switch plunger depressed (Taped down) and the freezer temp from 0 - 10 deg F.
You will need to make a jumper wire to jumper terminals T to H inside the ice maker front cover to start the ice maker test. If it cycles with the jumper the thermostat is good. If it does not cycle then either the thermostat has failed or... there is no power coming from the door light switch. (Bad door switch)
If all of the system tests pass and you still do not have water.... suspect the inlet water valve (pictured above) or the water supply as the source of the problem.
More often than not.... the real problem turns out to be ice build up on the evaporator coils due to an automatic defrosting problem. Should you discover a build up of ice on your evaporator coils do a MANUAL defrost session by unplugging the unit and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so be ready!) After the manual defrosting return the unit to normal service. You should have ice again within 12 hours. Keep an eye on the evaporator coils for the next 5 days because if you do have an automatic defrosting problem the symptom WILL return in a matter of 2 - 4 days. If the ice block returns.... have the automatic defrosting problem corrected to keep your ice maker working normally.
Thanks for choosing FixYa,
Kelly
Apr 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator Freezer has ice forming in the bottom inside freezer section. It appears to be leaking down the back inside compartment. The top section has an ice maker and water dispenser but I haven't had...
I believe you just described a defrost condensate blockage that is causing the leaking. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan, water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Freezer and Refrigerator section stopped working
check your drain line and check defrost system, defrost thermostat, heater, and timer
Nov 30, 2007 | Maytag PTB2154G Top Freezer Refrigerator
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
393 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
