Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My LG TROMM reads a blinking LE message
Reads blinking LE message and acts like it wants to spin but will not
I have tried to rum with machine completely empty and still get the same symptoms
  • 1 more comment
  • stephenhall Feb 15, 2009
    same problem. tried the unplug fix I read online, didn't work. Sounds like a belt is slipping.
  • Anonymous Feb 16, 2009
    washer won't spin giving OE message
  • Anonymous Feb 24, 2009
    same do you fix this problem?
  • 640 Answers
Motor locked...not and easy fix but if you want to give it a go let me know...onthejob
Posted on Jan 30, 2009
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
My lg tromm washer is reading LE. why
le is code 4 faulty motor or motor sensor. if u r confident, change sensor first. 95% of the time it is sensor. if u need more help please reply back
Apr 06, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE Tromm Washing Machine
i think you mean LG Tromm washing machine ... and the error code is LE ... thats a common failure with this machine .. often its cause by a defective " Hall effect sensor" this is used to detect the position of the wash basket ... if you are handy with tools then you can change it yourself at low cost ... but it does require removing a big bolt, the spin basket and several small bolts ... not difficult for a mechanic but probably more than aunt martha would want to tackle .. the URL listed below will give you good information on how to do that job ..
Aug 18, 2009 | LG WM2688HWM TROMM SteamWasher
Washer stops in the spin cycle with message LE
LE means overload in motor it usually comes on because you have an unbalanced load
Feb 16, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Le code and will not drain or spin
I read a post on another site, here is the link for the owners manual, see page 18 for the LE error code
I simply unplugged my machine for 30 seconds, plugged it back in and it worked like a champ.
Oct 13, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine
ngafm at your service!
Lets try this first!
Unplug the washer for 5 minutes and then replug and try it to see if this reboots the system like when a computer acts up, we do the same thing for most electronic devices!
If for some reason this is not helpful, open the user guide and see what the tell you is the meaning of a code"le" on your specific machine!
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Jul 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
260 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
