Question about Exercise & Fitness
Wiring diagram for mcb
Gold treadmill ag-10302 circuit board diagram
3 Suggested Answers
SOURCE: Wiring diagram need for an Smoothfitness EVO treadmill.
Solved this problem by contacting the Evo/Smooth directly. Great service.
Posted on Oct 20, 2009
ercupa190
  • 12223 Answers
SOURCE: i have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
Posted on Dec 31, 2012
Why display cannot receive signal from motor main board
Check the wire harness from the console to MCB.. Most likely the wire is pinch between the frame and upright post.
Apr 09, 2015 | Life Fitness LifeFitness T3 Treadmill
I have a NordicTrack C2420 treadmill and it looks like I am having issues with its motor board (MC2100WA).
sounds like a MCB problem, I have MCB's in stock ready for shipment, Elitefitnessrepair@gmail.com
Apr 03, 2015 | Nordic Track Nordictrack C2420 Treadmill...
Treadmill Protec Forerunner 3000 E 7 light on (mother control board FH-3545C-E, VER:B2)
Step 1:
you will have two alternatives:
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
Step 2:
1_4_2013_6_15_26_pm.jpgelevation motor diagram
Step 3:
treadmill motor control board diagram
Jan 04, 2013 | Sportcraft Exercise & Fitness
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
Dec 31, 2012 | Reebok Exercise & Fitness
Treadmill wont run
LUBE the deck belt, maybe you have WORN deck belt, by the lack of lube. YOu must do it aprox every 5 hours of use.
2) LUBE the rollers bearing.
3) Test the input voltage motor, see my personal TIPS how to troubleshooting the motor , see the diagram attache
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Nov 20, 2012 | Horizon Omega II 1.75 HP Drive Motor
Reebok 11300 treadmill I have had decided to move the machine and in doing so the wires became disconnected, what colours go to what on the mains socket. The rest remained untouched. Is there a circuit...
The wiring diagram is under your motor hood in an envelope. Also look at the other end of the harness - the wires are in the same sequence. Just be sure to get all the insulation out of the connector before trying to reinsert the wire. Must insert wire with insulation on it. These are the red connectors I am talking about.
Jan 15, 2011 | Reebok Exercise & Fitness
When I try to start the treadmill, the circuit board heatsup, one led is flashing fast, but the belt is not turning. Could you help?
I would first disconnect the drive motor and see if the motor control board is still heating up if it is then that MCB needs to be replaced. Call the manufacturer give model and serial numbers they should be able to take care of you.
Feb 26, 2010 | Proform Exercise & Fitness
Oct 19, 2009 | Exercise & Fitness
Tech support for New Balance 1400 treadmill thinks that motor stopped due to fuse on circuit board. Where can I get the fuses?
In general, I haven't ever seen the MCB fuse ever blow. But the fuse should be visable if you remove the lower cover and look at the circuit board, most of these are of the old style automotive type and can be found at an auto store. more than likely a transister is blown and the board itself needs to be replaced, this usually happens due to the deck not being lubricated
Aug 22, 2009 | Exercise & Fitness
Treadmill trips electrics
Check to see that the treadmill does not draw more amp than stated in the owners manual. If you are, then the problem is in treadmill. If not try another circuit in the house (not just another receptacle).
Jan 09, 2009 | Proform 380 CS Treadmill !
Exercise & Fitness Logo
73 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
