Question about Sylvania 6427TE 27" TV
Our TV Sylvania blocks some progrfams on ch. 51
When we switch to channel 51, some of the program are blocked. The screen turns black with a message: "Protected program by TV-14".
How to remove this block?
  • iprager Jan 25, 2009
    We have General Settings, and no Set up. Are they the same? In General settings there is no V-chip settings.
    How to get to V-chip setting?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
Go to the TV setup menu and look for the V-Chip settings. Turn it off altogether or if you have children you may want to just raise the block up to MA, R, or X rated programs
Posted on Jan 25, 2009
  • Mike
    Mike Jan 25, 2009
    If you push the settings button on your remote does it give you different menu pages? It may be labeled as V-Chip, Content Lock, Parental Controls, etc.
Dont have the remote control cant turn to channel 3 or 4 dont have a menu button
Isn't there a channel Up/Dn button at the front panel of this TV. It should be there. Only Menu button is not. There is Ch up ' Ch Dn and Vol Up ' Vol Dn buttons, beside a power button. Even pressing the channel Up ' Dn button, the channels cannot be changed, check the micro switches inside the TV. Replace them all at one time. You ave to open the TV to access these components.
Aug 02, 2012 | Sylvania 6719DF 19" TV/VCR/DVD
I NEED A CODE TO WATCH CERTAIN PICTURE. CAN YOU HELP?
hi
do the following to exit the code option.
p { margin-bottom: 0.21cm; }
1.Press MENU to see the menu.
2.Press VOL+ or VOL- to highlight SET.
3.Press CH+ or CH- to select PARENTAL CONTROL.
4.Press VOL+ or VOL- to see the SECRET CODE screen.
5.Press the Number buttons to enter your four-digit secret code.
[The code will appear on the screen as you enter it. The code "0000" is the default of the
TV. If you have not set up a code previously, then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000").]
6.Press CH+ or CH- to select MASTER ENABLE, BLOCK UNRATED,or BLOCK NO RATING.
MASTER ENABLE: This is the "master switch" for Parental Control. When ON, all blocking/censoring is enabled.When OFF, all blocking/censoring is disabled.
BLOCK NO RATING: All programming with NO content advisory can be blocked if this feature is ON and MASTER ENABLE is ON.
BLOCK UNRATED: All unrated programs (based on Movie Ratings or TV Ratings) will be blocked if this feature is ON and MASTER ENABLE is ON.
7.Press VOL+ or VOL- to turn the blocking option ON or OFF.
8.Press TV/AV/EXIT to remove the menu from the screen.
ok
Jan 13, 2011 | Philips Magnavox 27MS343S 27" TV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Cannot get lower channels
this is a chennel SKIP fuction . set any ch. to out of the tv memry .so you are reset this ch. pls open tv menu sysem and select edit ch. function .
if your tv ch.no.4 is blocked [skip]. set edit ch no:4 see this ch. is SKIP ON if yes then reset to v- or v+ [or arow key] to set SKIP OFF see this ch. no:4 is view perfactly
if your problum is not solve. pls infom me with your tv brand name and Model no.
Oct 07, 2009 | JVC AV-27230 27" TV
Lock access code
Just follow the steps carefully and you should be up and running again. Thanks for the model number.
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
Aug 19, 2008 | Hitachi 51F500 51" Rear Projection...
Sylvania
many channels read "protected program by TV 14" this started with only one channel and one by one other channels are added now can only receive ch 4, 7 and 13.
Jun 24, 2008 | Sylvania Televison & Video
Weird remote action, no cable, worked fine last night.
called for reset on programming by Cox Cable. Worked...amazing!
Mar 10, 2008 | Sylvania 6432TE 32" TV
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Jan 27, 2008 | Sylvania 6432TE 32" TV
32 inch sylvania tv
To fix the problem:
Nov 23, 2007 | Sylvania 6432TE 32" TV
Sylvania 6427TE 27" TV Logo
259 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Dave Naylor
Dave Naylor
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
