Question about NEC Electra Elite 32D-1 Corded Phone
I NEED to cancel warning tones...
The NEC switchboard I have to use every day is driving me quite batty with beeping that starts after someone has been on hold for 60 seconds. The only way around it is to either take them off hold then put back on, or turn the volume right down, which unfortunately also turns down the ringing volume. Does anyone out there know if I can cancel that "Feature"? Frustrated Receptionist
  • Nicole Creber Jul 13, 2007
    Thanks a bunch! I.T. department are going to re-programme it for me, and the rest of the office is grateful too!
    Novelist:
  • 201 Answers
You cannot cancel the feature but the on-hold recall timer can be increased. This is a system programming feature that will effect all phones. You could change the timer from 60 seconds to say 240 or more. Do you know who is in charge of making programming changes for your system? You may have someone at the office or you may pay a company for adds, moves & changes. As far as programming goes, changing a simple timer is about as easy as it gets but it's still a bit complicated and would require a programming manual for your phone system (not the phone) so the first step is to find out which NEC phone system you have.
Posted on Jul 12, 2007
On the IP1NA-12TXH, pressed the call1 button and now the screen says switchboard. how do i go back to the regular name display?
If your phones says "switchboard" that is the name assigned to it. in idle condition you should have a name and an extension number as well as the time and day showing on your Aspire phone.
Oct 02, 2014 | NEC Lands Phones
Motarola gp340 does not beep when switched on, can you tell me how to make it beep when you switch it on. Thanks
You will need to go into your settings (sound settings or profile settings which you are using) and enable (turn on) warning tones.
Hope this helps and please rate thanks
P.S if the profile is on silent, there will be no beep. Change profile to general and turn up volumes and enable warning tones.
Mar 23, 2011 | Motorola GP340 Two Way Radio.
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Constant beep even while driving and when i turn it off it still beeps unless i disconect the interior lighting fuse and plug it back in fuse # 8 i believe. if i leave the fuse out it makes a wierd sound...
1995 GrCher Orvis - I have now just started with the same problem. An incessent loud high pitched alarm sound. Identical fuse, ignition on/off, and ticking issues. Can start jeep, warning sounds as normal followed by incessent tone, I can remove fuse to get quiet, but then when I close the door I get the identical alarm sound, but with a slight pause. Tone. Tone, Tone, etc. I can't figure. Tore through all components of dash: to learn that the alarm seems to emminate from the transmission floor area, and is not in the instrument panel (f up #1) nor is it behind the dashboard (f up #2). I'm stuck now... Anybody got something for me? Is it a transmission warning?
May 28, 2010 | 1995 Jeep Grand Cherokee
Beeps while driving
My van did this aswell, you must have a power sliding door, when it is not latched properly this warning goes off but it won't say on your message center "door ajar". Stop and reopen the door and close it again no more bell. good luck.
Aug 19, 2009 | 1999 Pontiac Montana
THERE IS A BEEPING NOISE THAT STARTS AFTER DRIVING IN MY 2000
Here are the warnings:
The generic electronic module (GEM) controls the following warnings and chimes:
  • Driver safety belt not fastened (warning lamp and repetitive chime).
  • Key-in-ignition (repetitive chime).
  • Headlamp-on warning (repetitive chime).
  • Door ajar (warning lamp and single tone).
The following four distinct chime rates are used to indicate warning:
  • Seat belt warning chime is one chime per second.
  • Key-in-ignition warning is two chimes per second.
  • Headlamp-on warning is four chimes per second.
  • Door ajar warning is a single chime.
please rate as solved if this is what you needed.
May 19, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Function
If your main system cabinet (in some closet somewhere) is plastic, you have the NEC Electra Professional Level I system and the DND cancel procedure is <FNC>, 60, <FNC> when the phone is idle. If your main system cabinet is metal, you have the NEC Electra Professional Level II system and the DND cancel procedure is <FNC>, 69, <FNC> when the phone is idle. You can also press "42" while hearing intercom dial tone. The most common cause of accidentally setting DND is by dialing "40" while hearing intercom dial tone (Level II system).There is a slim chance your main system is not the Electra Professional series. If either of the above do not work, let me know.
Jan 15, 2009 | NEC ETW 16DC-1 Corded Phone
Beeping
When you turn key on check if airbag light on instrument cluster comes on. 5 beeps is the tone to let you know your airbag light in instrument cluster is inop..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/terry_db4da071b7da3ac1
Sep 03, 2008 | 2003 Ford Escape
BIS 34-D phone - Display window blinks date time beeps multiple times/day
The display will blink if power is cut either by unplugging or if the control system is power-cycled. The cause of the power glitches needs to be located & corrected. Changing the ring tone/cadence depends on which control unit is being used.
May 27, 2008 | AT&T Merlin BIS 10 Phone
Recharging phone constant beep
When misplaced in the charger the xg2200 beeps, are you sure the phone is placed correctly? please let me know. Good Luck
Mar 01, 2006 | Xact Communication XG2200 Cordless Phone
NEC Electra Elite 32D-1 Corded Phone Logo
167 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
