Question about Sony Cyber-shot DSC-W100 Digital Camera
Access When I turn on my camera, I get a black screen that says "Access", then I am instructed to turn my camera off then on again. This does not solve the problem. I ca use every other function on the camera except taking pictures. I have swapped the battery with a known good from my other camera. Thank you.
  • Cody Koch Jul 12, 2007
    Please, I work on electronics and I cant find any documentation for this camera.
    WHen I turn on the camera, the lens goes in and out 3 times, next to the veiw finder the orange light blinks. Still get the new lens??
I had the same issue. Lens would move in/out say 3 times but camera did not start - Power off message. Suspected jammed gears - So tried the 'gently' bang several times on solid but carpeted floor (with camera off and lens retracted). Did the trick for me.
Posted on Sep 12, 2007
  • 34 Answers
It's the internal focusing lens assembly not functioning properly. It's not uncommon for these to jam up. I've fixed several of them, but sometimes they can't be fixed, and the lens needs replacement. A little hint...buy a used DSC-W1 on eBay with a good lens. It's the same lens assembly as the DSC-W100, and it's a lot cheaper used than the W100.
Posted on Aug 27, 2007
    Sergeant:
    Champion:
  • 326 Answers
Hello, there is a problem with the optical unit (lens). Normaly when the camera is in camera mode the lens should go out. In your case it seems that for some reason the lens is stuck. Please contact your nearest Sony dealer. If you want to repair the camera yourself please tell me. I can send some additional info as well. Regards, Arpi
Posted on Jul 12, 2007
  • Arpad Kothai
    Arpad Kothai Jul 12, 2007
    here is the part number for the optical unit (lens) A1060696A
    Best regards,
    Arpi
  • Arpad Kothai
    yes, please replace the lens unit.
    Best regards,
    Arpi
SOURCE:
Black lcd screen and cannot operate digital camera in any way
Sound like a LCD screen problem and will need to send at technician in order to solve it.
Sep 03, 2012 | Sony Cameras
I have had my camera for about 4-5 years. It has worked great. lately it has started to act weird. when I turn it on the screen says access and wont let me take a picture. then after a few minutes the...
Go to camera Menu and select Initialize, OK.
Camera will turn on itself, if problem still exist, tap camera gently and turn On again to solve lens access problem.
Memory stick error can be solved by formatting it through Format menu in camera. Use another memory stick in camera to make sure that camera is OK.
Aug 12, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
try to remove the battery for a few minutes this should refresh its system once you power it up again.
Aug 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony camera problem
hi there
turn on
gently hold end of lense and twist and pull gently you may hear a click dont force it
turn off and on again and the problem should be solved
Sep 07, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot
turn on
take hold of the end of the lense
gently twist and pull the lense you may hear it click but dont force it then turn on and off and this may solve your problem
Aug 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
DSC-W50 sony cybershot
I had the same problem with my DSC-W55. I actually just called the customer service number on the sony website and they told me how to solve the problem.
- Take your battery out
- Press and hold the power button for 60 seconds
- Re enter your battery
- Voila.. it should work when you turn it on. Mine did.
Nov 19, 2007 | Sony Cybershot S650 Digital Camera
Screen shows only 'Access'
You have probably dropped the camera. If you are brave enough to open the camera up you can put the rollers back on track. Not a difficult problem to solve.
Oct 17, 2006 | Sony Cyber-Shot DSC-P93 Digital Camera
'Access' screen?
the (Access) in the screen refer to one of this problem, the lens mechanism is unable to start due to plastic broken parts in it or dust, or battery poor power, use a rechargeable battery over 1200 uAh of power
Jun 13, 2006 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
111 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
