92 Honda Accord, 5 speed, hard shifting into first & second gear.
First thing to do,try to pump your clutch before you shift into 1st gear then if you feel makes better, most probably you have problem with your hydraulic clutch system, check the clutch line if there is an evidence of fluid leaking or it could be internal leak.
Second thing to do, check your transmission oil, may be it' s too old or you use a thick oil thats why when cold its hard to shift then when the engine rich the normal temperature(warm) the oil become thin and the shifting will smooth. Remember the very old oil become thicken and the purity is gone and can cause of hard shifting. in this regards i suggest you to change the transmission oil and check the used oil if there is small peace of metals, then you are in big trouble,
