Question about HP Compaq Presario SR2011WM PC Desktop
My CD ROM/DVD on my computer drive wont open? Why not?
It just doesn't want to open when I push the open button. Its crazy and Im just wondering.
  • julian_loves Jan 25, 2009
    THANK YOU THANK YOU THANK YOU!!! IT OPENED AND WORKS AND NOW I AM SO APPRECIATIVE FOR YOUR HELP! You guys rock! =]]]
  • monin10 May 14, 2009
    i have the same problem, but i dont want to pay for the software, plus i dont even have a credit card....where can i get a software free?
    someone please tell me.
  • 51 Answers
Try either right clicking on the CD drive icon in My Computer and see if it opens, of not put a straightened paperclip into the small hole on the CD drive face and push into open it. Does the light flash or does it make any noise. I would make sure that it isn't jammed by trying the first two. If all is good, then go into Device Control Panel->System->Device manager->DVD\CD-Rom Drives and see if your drive is showing. If it is then right click and click Uninstall and then restart your system. It should find new hardware and reinstall the drivers for your driver if it is working properly.
Posted on Jan 25, 2009
  • 33 Answers
It is very possible that there is a CD stuck in the tray. Most commonly you can find a small pinhole on the front of the CD drive. You can stick a paperclip in this hole,, and the drive will manually open. If you find that there isn't a CD stuck in the drive, and the problem persists, you will want to look into buying a new CD drive. They cost roughly around $25 dollars. You will want to buy an IDE 3.5" CD rom drive. It is very easy to install. Just take the side cover off while the computer is off. take the 4 screws out on the side of the CD drive, and pull out the two plugs on the back of the cd drive and pull it out of the front. Reconnect the cables, put the screws back in, close the cover and you will be good as gold. If the PC has Windows 98 or below you may have to install the drivers. Good Luck!
Packard bell PC DVD rom won't open
Not quite sure what you mean ? which button on top (power button)
The button on the dvd is the only one to open it.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive.
Jan 15, 2014 | Packard Bell Computers & Internet
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Cd stuck in emachine and there's no pin hole
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
My cd rom wont open
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
also if there is a small hole on the front of your cd drive push a straightened paperclip until you feel it push down on a button this should open up the cd drive
hope this helps you
Sep 06, 2011 | Dell (0F146) Internal DVD Drive
I emachine dvd rom/burner won't open how can i open it? but before it really do not play any dvd and then now it wont open.
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 05, 2011 | E-Machines emachines (emachinees) CD-ROM...
My lite on dvd ram wont open its lid no matter how many times i tried to push the "open" button. it sounds like something is stuck inside but im afriad to open it for i might add more damage.
make sure that the dvd-drive is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd drive then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 16, 2011 | Lite On LiteOn LH-20A1P - Disk drive -...
Ch08ls10 lg wont recognize dvd+r
Click the Windows "Start" button, and open "My Computer" -- if you don't see an icon for the CD/DVD drive, it's not correctly connected:
* no electrical power
* no data-cable
* jumpers on drive (MAster, SLave, CableSelect) improperly set
* just a "defective" drive
Does the drive-tray open/close when you push the button? If so, you do have electrical power.
Do you hear the drive spinning, or feel it vibrating,
when you insert a disk?
Best guess: shutdown your computer, move the "jumper" (MA, SL, CS) on the "back" of the drive to a different position, and restart.
Jan 27, 2010 | LG Black 8X Blu-ray/HD DVD-Rom LightScribe...
I connot open the windows.windows showing NTLDR
this could be the computer trying to boot off a USB device plugged into the computer.Check that you don't have any USB devices plugged in. and no CD in the drive. then reboot the computer.
Dec 09, 2009 | Acer Aspire One PC Notebook
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
HP Compaq Presario SR2011WM PC Desktop Logo
297 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
