Question about Hunter Fan Company 5/1/1 Programmable Thermostat
3 Month baby and need help hooking up thermostat ASAP
I have an Hunter Thermostat Model 44155C. The labels say G, Rc, Rh, Y/O, W/B, an Y1. The wires are green red yellow white black brown orange. Which goes where? Need ASAP Have 3 month baby at home and no heat.
    Problem Solver:
  • 13 Answers
The wire colours mean nothing. If your old one didn't have letters or you already disconnected it, you will have to go to the furnace. Under one of the panels there will be a control board to which the thermostat wires connect and this might have the letters printed on it. Trace them back and connect them appropriately.
If you have a furnace that is like mine (a single-stage natural gas one), chances are that R is +24V, C is common, W is heat call, and G is the blower. Y is generally cooling. The furnace could be turned on by connecting R, W, and G together, I suppose, if the above doesn't work... but it won't shut off automatically.
Posted on Jan 28, 2009
I HAVE A HONEYWELL THERMOSTAT THAT HAS BROKEN. IT HAS 7 WIRES. G-GREEN C-BLUE R-RED Y-YELLOW L-BLACK W2/E-WHITE O-ORANGE ITS ELECTRIC WITH NO BATTERY. I BROUGHT A HUNTER THERMOSTAT WITH BATTERY. ALL IT HAS...
Shut power off to Air Handler first before hooking up the thermostat..... Looks like the Hunter Thermostat does not have a Common Terminal...... Is it a Heat Pump thermostat???? I am not a big Fan of Hunter Thermostats they do not have the features that Honeywell thermostats have.
Back to your Question:
G to G ; R to Rc&Rh : O to Y/O; White Wire to W/B; Y to Y1;
L-Black is not used it was for a service lite
C-Blue will not be used it was the common wire
With the Hunter Stat you will not have an emergercy heat option
May 24, 2011 | Heating & Cooling
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
I am trying to wire a hunter 44550 to furnace. Old programable not much help. Hi have 5 wires comming from wall. Black, red, yellow, white, blue, Furnace has W, RH, RC, G, Y/Y1, and O/B terminal Any idea...
Depending on where the wires were connected on the old thermostat, would be the best place to start, but if that is not an option you could try to trace the wires back to your furnace and see where they connect to. It appears you have either an oil fired furnace, or a single stage heat pump. If you need more assistance please just provide type of heat used. Hope this helps
Mar 07, 2009 | Hunter Fan Company 7-day programmable...
I am replacingh my thermostat. it's a honeywell xt302c. im replacing it with a hunter 44660. the wires are different letters. here's what's hooked up on the honeywell and available on the hunter: Honeywell...
Thanks for your Question,
B- is your common leg,
RH- is your hot to heating
RC1- you will not need
RC- you can use if you remove the jumper for cooling
Y1- you will not need
G- is your fan
O is not needed, wires should be hooked in as follows,
RH- red wire, heating
RC- Yellow wire, Cooling
G- Green wire, Fan
B- Blue wire, for common leg, this one might be a different color so make sure at the furnace which T-Stat wire is connected to Common, you should check all the wiring at the furnace to make sure this pattern of wiring is followed, it should be standard practice to hook them up this way, but not all installers do it, thanks again, please rate this,
mr.grzz
Jan 25, 2009 | Heating & Cooling
I have an old janitrol thermostat with terminals marked R,Y,G,O,W2 and I want to replace it with a Hunter 44360 Programmable Thermostat with terminals marked G,RC,RH,Y/O,W/B,Y1 What wires do I hook up to...
Hook up like this:
R-RC (jumper rc with rh) unless you have more than one transformer
Y-Y/O
G-G
O-Y/O (depending if reversing is energized by O or B terminal, refer to your manual)
W2-WB
Dec 06, 2008 | Heating & Cooling
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
430 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
