Question about Mitsubishi WS-73711 73" Rear Projection Television
Picture is seperated by different colors
This is a 8 year old Mitsubishi WS-73711 73 in. Rear Projection TV.
The picture on the screen is seperate for each color creating a ghosting effect. Its pretty bad. Everything is showing a double on the screen and you cannot make out anything. Even the menu items are hard to read.
I thought it was convergence problem but setting it to factory default is not solving the problem. It does not even make a difference.
  • rajunath Jan 25, 2009
    Thanks for the response. Quick question what is the cost of the capacitors and labor to fix this. If its too expensive - I'd rather put that money into a new tv.
  • Mitsubishi Master
  • 19,396 Answers
You need to do a convergence setup procedure.
Hope that your problem is solved .
Many thanks for using Fixya.
Posted on Feb 15, 2009
  • 1,199 Answers
There are capaciters on the circut board are burnt out and will need replaced!
You can not fix this yourself
Posted on Jan 25, 2009
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
Red and green colors seperating screen is like a double picture
Replace Both of your convergence ICs STK392-570 Call Mats 1-800-628-1118 $10.95 each
Dec 31, 2009 | Mitsubishi WS-55411 55" Rear Projection...
The colors are seperating and screen picture is bowing in?
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 26, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
did you replace the tw0 5 amp pico fuses F9A04 and F9A05 as they usually open when an IC fails
Jan 24, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
WS-65907 picture problem
Try resoldering the convergence ICs mitsubishi has been known to be a little stingy on the convergence IC solder in the past.
May 15, 2008 | Mitsubishi WS-65907 65" Rear Projection...
WS-65907 Picture problem
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
The reason that they might snap back into place when you hit the base is that they are actually three different colored picture tubes or rods. By hitting the unit, you are moving these. I would suggest doing convergence on a regular basis and to avoid hitting your tv. :)
I hope this helps!
Go Ahead. Use Us.
May 14, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WS-55311
check the error codes to see what's wrong, do this by search threads here or at
Dec 31, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-73711 73" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
