Question about Kitchen Appliances - Others
T-fal avante toaster brand new only toasts on inside coils.
  • 267 Answers
First check if the bagle button is stuck in and that would make the outside elements go off ..... if not the control board is bad . there are no parts made for sale for this toaster sorry
Posted on Feb 19, 2009
Problem with the T-Fal Avant Elite OT806552/4YA-4804 Toaster Oven. Oven won't come on at all, how do I get the cover off to check it out? Is there a fuse or breaker that I can replace. Thx. -mahen
I have the same toaster and the fuse burnt out a couple of days ago. Its a 10 Amp fuse behind the control panel under a white cover. You will need to remove the right side of the oven to see it. I've not found a replacement fuse yet. Let me know if you find one.
Mar 20, 2011 | T-Fal Avant Elite OT8085002 Toaster Oven...
Lever will not stay depressed
Hello. The first thing to try is to set the toasting level to a darker setting. Often this alone will solve the problem. If not, the mechanism which prevents burning or even a fire is simply worn out and it is time to buy a new toaster. J.
Aug 04, 2010 | Tefal Avante Elite Programmable - 2 slices...
Heating element no longer works. is there a fuse or is it the coil that's the problem?
I had the same problem and discovered it was the plug on the heating element was loose. I'd check continuity with a ohm meter across the coil. If it shows a closed circuit there isn't anything wrong with the element itself and could be as simple and cheap as tightening up the connector.
Dec 28, 2009 | T-Fal Avant Elite OT8085002 Toaster Oven...
Lever to lower toast has snapped off just inside the toaster casing. It is plastic and cannot be reattached
Hello Sue, I've attempted to locate replacement parts for for Tefal Avante toaster, but there doesn't appear to be a broad source for these, which troubles me as I've got the same toaster and use it everyday.
I did locate the Tefal customer support/service contact that should be able to provide you with either a local authorized service location or provide you with the replacement parts you need to get it working again.
You can call Tefal directly at 1--800-395-8325 from 8:00 AM to 5:00 PM Monday thru Friday, EST
Here's a link to the contact page, in case you prefer to send an email instead.
With luck, Tefal will be able to assist you in getting your toaster working like new soon.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Tefal Avante Deluxe 2 Slice Toaster
T-Fal Bagel toaster makes buzzing sound
I'm not sure if this applies to your problem, but I found a great solution to the buzzing I've experienced on my GE toaster at the following link:
Jan 04, 2009 | Tefal Avante Deluxe 4 Slice Toaster
Lost manual for T-Fal Avante Elite convection oven 028085002
Follow this link and it will have what you need. I hope this helps you.
Nov 30, 2008 | T-Fal Avant Elite OT8085002 Toaster Oven...
T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Kitchen Appliances - Others Logo
149 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
