Question about Intex "" Metal Frame Pool Set (56998e) 56998e
Need liner I need a metal frame pool liner only, but can not locate one. any suggestions?
KMusselmann
  • 247 Answers
SOURCE: Water loss in pool, but no hole in liner
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
Posted on Mar 23, 2009
  • 297 Answers
SOURCE: I have the 15' X 42'intex metal frame. Pool and
Watch the video at itex.com
Posted on Jul 12, 2009
  • 10865 Answers
SOURCE: I need the instructions to set up a 18 round metal
Hello. Go to the link below, enter the model and year of your pool and then you can select a video and or a downloadable manual of instructions. Joe
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on May 07, 2010
  • 2841 Answers
SOURCE: Lost instuction manual and dvd- new pool for metal frame
Right here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Posted on Jun 01, 2010
jharwell668
  • 640 Answers
SOURCE: 24' x 52" metal frame pool, need copy of set up manual.
I don't have an instruction manual for this particular pool, but I do have general installaton instructions for above ground pools with metal frames and liners. The pool liners are the same to install no matter what type of pool you have, so this should help!
Posted on Jun 24, 2010
Swimming pool
NOT from Outside.
If Possible empty pool now with a Controlled drain...
Peel back liner and clean area real good. Sand or steel wool to remove rust. Then Paint using one of those "Rubber" based leak sealing paints found in your local DIY warehouse store.
Then place a piece of Thin sheet metal against the wall after paint dried. Replace liner, coping strip, ridgidizing metal bar, and top rail.
Refill.
or if you're lucky...
Patch the liner. When all is dry, use 3 applications of Epoxy Putty like JB Weld. Place a small covering over the DRY area with the hole. If possible, force some into the hole.
Once dried and cured, place a 2nd patch, slightly larger over it, and then repeating a 3rd time, again slightly larger.
Not as good as First method, but may still work?
If left unattended...
The water pressure in the pool, will push the liner right thru that hole - like a hernia, and will burst thru releasing all your water and possibly collapsing the pool? This will be an "Uncontrolled" drain vs. the controlled drain above.
I guess you can choose which way you want to drain your pool?
Weld 8265S Original Steel Reinforced Epoxy Twin Pack 2 oz
Jun 14, 2015 | Pool & Spa
SMALL HOLE BOTTOM OF 15 x 4 metal frame pool. believe a small pebble caused it. water leaking out is there a way to save the poolwithout draining and taking it apart?
Try this....
You will need;
Pool liner patch kit
Goggles
Body weight to hold you down while doing repair under water.
Most liner repair kits have instructions on wet applications. Cut a piece of the liner kit fabric to cover the entire hole plus at least 1/2" around. You will need to dive in with a mask/goggles to see the hole. Put a thin layer of glue on the patch and spread evenly.. Fold in half on the glue side and go down to the bottom of the pool. Note...The weights will help you stay at the bottom for this part of the repair.. QUICKLY!!! while holding the patch next to the hole. open the patch and place on the hole and push firmly for a few seconds. Come up and place your foot on the patch and hold for 3 minutes or so. Should work...It took me several times to master this technique when I had a hole at the bottom of my pool... Caution!!! You don't need a lot of weight to stay at the bottom. Test from light to heavy until you think you have enough to do the repair..
Good luck and hope this will help you!! If this works for you, please rate!
Jul 19, 2011 | Intex Easy Set Pool 15x36
Have an Intex 12ft x 3ft metal frame pool. Set it up first and filled it and it lost more than half the water overnight. Did everything I was told to find the leak and nothing. Was on hands and knees in...
what is not included in the instructions is the simple " lay down a bed of filter sand around 3" thick before placing liner in the pool frame and radius it up at the bottom corners
that sand is necessary because any small pebble , rock or edge will cut the thin liner under water pressure or feet walking in the bottom of the liner
further more , if you use chlorine as a cleaning , antibacterial agent that will cause pin holes in any part of the liner not completely covered by water
Mar 26, 2017 | Sport & Outdoor - Others
My pool is leaking where the sides are joined to the bottom how do i repair this leak
Hi
You don't have much choice in the matter. Either find and repair the leaks using a proper vinyl patch kit with underwater glue ( you can get this at your pool shop) or buy and install a new liner.
Thanks for using Fixya.
May 22, 2011 | Intex "" Metal Frame Pool Set (56998e)...
When you set up a metal frame intex pool is it best to set it on sand or is there another way to set it up
Sand is always the best way to go. This way if the pool frame, liner, or even the ground shift a little it has no ill effects. The sand just conforms to whatever is on top of it and to a degree, whatever is below it as well. Soft soil works okay, but it depends on the part of the country you are in. Definitely not good to try on hard ground or anywhere there are rocks and debris.
Apr 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
Intex changed product materials of pvc pools
You would think that two tarps would be enough, lol
I would get weed killer and kill the grass or put sand over it. the last suggestion is diggin it up and then putting sand over it to level it back up.
Please rate and let me know if it helps.
thanks and God bless
Jun 25, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Jun 09, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Replacing liner 18x33: forgot to unscrew pump from alum. frame while filling pool. is it safe to cut a **** in the liner to pull the plate through or would it be safer to take the foot rail and coping
I have never had to cut a hole in my pool liners when installing them. What kind of hole are you trying to cut - I am not sure what you mean by pulling the pump cover through? If you will provide further details about what you are trying to do, I can help you better.
May 24, 2009 | Swimline Liner Guard Floor Padding 33'...
Kurt
Mar 23, 2009 | Intex Frame Set 12 ft x 30 in Pool with...
Intex "" Metal Frame Pool Set (56998e) 56998e Logo
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
