Question about Canon DR 2080C Path-Through Scanner
Canon DR-2080c - Replacing rollers
I have a Canon DR-2080c (connected via SCSI) scanner. The scanner is a little older and now is grabbing multiple pages at once. I think the rollers rollers inside the scanner need to be replaced... On the internet, I see there are "******" rollers or "exchange" rollers. What does each one do? Does one of them determine how many pages to grab? Thanks!
    Problem Solver:
  • 14 Answers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Posted on Mar 03, 2009
Having multiples feed even after replacing roller kit, If i put a little preasure on the top cover it will work fine any ideas??
Try rotating the sep roller backwards to reset the planetary gear. if that dont work you may have to adjust the stopper to allow the sep roller to move closer to the pick roller.
Aug 08, 2011 | Canon DR-3080CII Path-Through Flatbed...
How can i get capture perfect software for my canon dr 2080c?
Go to their official webpage, and try to find software... or just download this Driver Update Software for XP Vista 7 8 and make the update. I hope I have helped. Have a nice day
Paul
Jan 18, 2011 | Canon DR 2080C Path-Through Scanner
Is there a canon dr 2080c driver for Windows 7?
look in optional updates in windows. thats the cool thing with 7
Dec 26, 2010 | Canon DR 2080C Path-Through Scanner
Line appearing on document
Clean the glass thoroughly with a damp cloth.
S. Mohan
Sep 30, 2009 | Canon DR 2080C Path-Through Scanner
I recently set up a new DELL optilplex 760. When I go to install my Canon DR-2080c I get an error stating "Device Not Found". I've uninstalled and reinstalled many times but still no luck. Can anyone help...
Have you installed device driver? It is just not enough if you install scanning software. Also trya different USB port o a different USB cable.
S. Mohan, India
Jun 04, 2009 | Canon DR 2080C Path-Through Scanner
Canon Dr-5020 grabbing multiple pages
Wipe the rollers with a damp cloth thoroughly. Remove all the dust in the glass for a claen scan. The red color roller roller in the bottom needs thorough cleaning, rotate with hand gently (in power-off mode) and clean it thorughly. No solvents pls, except Isopropyl alcohol for cleaning
S. MOhan, Chennai, India
Mar 03, 2009 | Canon DR-5020 Path-Through Scanner
Does anyone know the difference between a canon ****** roller and an exchanger roller on a canon dr-2080c scanner? I am looking to replace the rollers that are ageing and now "picking" up more than one...
The exchange roller kit has all the tires that pick up the paper in the kit (feed, separation, and pick up tires). I think the other tire you are talking about is just one tire not the set.
Also check to see a switch on the scanner that is used for single feed or multiple feed. If its on single feed it will multi feed all the time. You can clean the tire with rubbing alcohol too, to see if your double feeding goes away.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
CANON 2080c scanner not scanning bottom quarter inch of page
Check your scan settings. If you have chosen A4 and the paper is slightly bigger, this can happen. It is also possible when the scanner does not pick up the paper in the first attempt because it is worn out. In such an event, you may find a blank on the top of the image. Clean the rollers with a damp cloth. Dont use solvents.
S. Mohan, Chennai, India
Jan 15, 2009 | Canon DR 2080C Path-Through Scanner
Canon 2080C scanner software causing monitor issues
Some sort of feedback through the scanner it seems Delete the scanner software and reinstall. Check Canon website for software updates Consult the Tech support team whilst you are there
May 31, 2007 | Canon DR 2080C Path-Through Scanner
Open Questions:
See all Canon DR 2080C Path-Through Scanner Questions
Canon DR 2080C Path-Through Scanner Logo
549 people viewed this question
old marine
old marine
