Question about Kenmore HE2 Plus Front Load Washer
My Kenmore HE2 Plus made a pop sound then the door locked up
We cleaned the drain plug and opened the door but it still wont run. If we turn it off it goes back to 85 minutes and the door locks again. Could it be electrical problem. The washer just stays locked and there isn't an error code flashing it just gets stuck on the minutes after you turn it off by the breaker box. It is stacked in a closet and too difficult to keep unplugging but we did manage to unplug it once and it made no difference.
  • 220 Answers
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Posted on Sep 03, 2009
kvhappliance
  • 218 Answers
SOURCE: Kenmore HE2 Plus error code F21
F21 Is a slow or long drain.
Things to look for kinked drain hose, Plugged or obstructed drain hose, Possible pump filter screen clogged, Least unlikely is a drain pump failure.
The pump filter screen is the most common it gets plugged with lint, coins, hair etc. It can be cleaned by the owner however is is a very dirty messy job and if you are not very careful you can end up with water everywhere. If you want to attempt it let me know. If there is anything else I can do to help please let me know.
Posted on Mar 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a kenmore front load washer 970-C47092 - it
Posted on Aug 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE2 Plus Washer won't unlock
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: washer is stuck on spin and the door wont open. It is locked.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Sep 11, 2010
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Open locked door
To open the door when locked. Start new wash cycle and the door will lock - unlock then lock again. when it unlocks open the door quick.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
Door is locked code F21 wont run or cycle or empty water
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Jan 13, 2010 | Kenmore HE2 Plus Front Load Washer
F21 code on kenmore he2 plus
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Mar 08, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
