Question about Proform Performance 1450 Treadmill
The screen of my treadmill is black and have a legend in white letters of "android", doesn't work nothing
91 Acura legend won't turn over. Changed the starter relay and checked the starter, it's good. Now what do I do?
Power flows from Fuse 35 50A to IGN switch. Start by checking that fuse. From IGN switch to starter on black/white wire. Check for battery voltage on that wire at starter. If no voltage, check for voltage on black/white wire at IGN when turned to START. If no voltage, check for good power coming into the IGN switch on the the white wire from Fuse 35
Feb 04, 2018 | Cars & Trucks
Android 4.1.1 tablet won't boot
If you can't boot you will have to perform a hard reset.
If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down. Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
  • Nexus 7: Volume Up + Volume Down + Power
  • Samsung Galaxy S3: Volume Up + Home + Power
  • Motorola Droid X: Home + Power
  • Devices With Camera Buttons: Volume Up + Camera
Feb 14, 2013 | OEM P90 9.7 inch Android 4.1 Jelly Bean...
Touch screen doesn't work
Reboot battery
Send phone in for repair
Oct 15, 2012 | Sony Mobile Communications Sony Xperia U...
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
Hello i have bought a hd2 t-mobile in USA. seller declared it works well. when arrived, i have changed WP7 with Android, but nothing more. Phone had a bad signal reception, near a HTC legend well...
There is a little white tab on the sidewall of the battery well - should be toward the top of the phone. If it's pink, it means there's damage to the inside and it won't be repaired by the manufacturer.
Apr 06, 2011 | HTC HD2 Smartphone
Proform Performance 1450 Treadmill Logo
29 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
