Question about Casio FX-115ES Scientific Calculator
54/10 rename mixed number
54/10 rename as a mixed number
How do I ID and # photos on already onmy SimpleTech
select the ones in the same folder and highlight them with your mouse Hold down your cntrl key and right click the first image. If all the images are the same category then rename the right clicked image, what ever you want it to be. Once you have renamed the one, all the highlighted ones will be renamed the same with the difference being, all the other images will have a number added to it in sequence.
Jul 26, 2014 | SimpleTech SimpleDrive Pininfarina 320GB...
Profile service service will not allow me to logon
First of all start your computer in safe mode. This can be achieved by pressing F8 during the start-up of your computer. If this is done correctly you'll get a menu where you can choose to start your computer in safe mode.
After it is booted in safe mode follow these steps:
  1. Click Start, type regedit in the Search box, and then press ENTER.
  2. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
  3. In the navigation pane, locate the folder that begins with S-1-5 (SID key) followed by a long number.
  4. Click each S-1-5 folder, locate the ProfileImagePath entry in the details pane, and then double-click to make sure that this is the user account profile that has the error.
    • If you have two folders starting with S-1-5 followed by some long numbers and one of them ended with .bak, you have to rename the .bak folder. To do this, follow these steps:
      1. Right-click the folder without .bak, and then click Rename. Type .ba, and then press ENTER.
      2. .bak, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493039.png" alt="2493039" title="2493039">
      3. .ba, and then click Rename. Change the .ba to .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493040.png" alt="2493040" title="2493040">
    • If you have only one folder starting with S-1-5 that is followed by long numbers and ends with .bak. Right-click the folder, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
      1. .bak, and then click Rename. Type .ba, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493038.png" alt="2493038" title="2493038">
  5. Double-click the folder without .bak in the details pane, double-click RefCount, type 0, and then click OK.
  6. Click the folder without .bak, in the details pane, double-click State, type 0, and then click OK.
  7. Close Registry Editor.
  8. Restart the computer.
  9. Log on again with your account.
Dec 24, 2013 | Computers & Internet
Multiplying mixed fractions
Convert each mixed number (what you call mixed fraction) to an improper fraction, then multiply the two numerators and multiply the two denominators. Reduce the resulting fraction to its simplest form
Example
(2 1/3)*(1 5/7)=?
Convert 2 1/3 to an improper fraction 2 1/3=2+ 1/3 = 6/3+1/3=7/3
Convert 1 5/7 to an improper fraction 1 5/7=1+ 5/7 =7/7 +5/7=12/7
(2 1/3)*(1 5/7)= (7/3)*(12/7)= (7*12)/(3*7)
The 7's in the numerator and denominator cancel one another leaving
12/3=4
(2 1/3)*(1 5/7)=4
Not all products of mixed numbers will give a simple result as this one. More likely they will not.
Dec 12, 2013 | Computers & Internet
I have a Casio TE2200 that has pre-programmed PLU names. I have tried to rename them, but it doesn't seem to carry through. How do you rename the PLUs? Also I accidently renames the address code...
You should normally be able to program all PLUs on thekeyboard as long as they have been setup.
Turn key to Program mode.
SUBTOTAL
Type new name
00 (double zero button)
Press a PLU to set the name
SUBTOTAL Hope this will help you. Good Luck.
Aug 13, 2011 | Casio Parts Cash Register PC Desktop
Won't play book chapters in order
Maybe it is simply that the device is set on shuffle play. That way it will play mixed up. You can however create a folder with your LB series name and place the files in there.
Best luck, let me know if you got through.
Aug 19, 2009 | SanDisk Sansa e260 MP3 Player
It renamed most files by adding a dot & five digit number (.12345) after the file name which I don't like. Why did it do that? How can I get the numbers removed? What can I do so that backups in the f
use different software to back up your files, and as to the (.12345) you would have to go through and rename each one, and yes it can take a very long time, been there done that
Apr 16, 2009 | Computers & Internet
Renaming audio tracks
Use mp3tag found here @ http://www.mp3tag.de/en/
It will help you organize everything and sansa depends on mp3 tags to organize everthing.
Aug 17, 2008 | SanDisk Sansa e250 MP3 Player
How do you set the image's filename to automatically include timestamp and date
Dear jeannesc:
I am assuming that you are using ZoomBrowser EX ver 5.8 which comes with the SD750's Digital Camera Solutions disc. Therefore these instruction will pertain to that version of the program.
You can rename image files using four different naming schemes:
1. Image Name + Number (e.g. Vacation_001.jpg)
2. Shooting date + Number (e.g. 20080601_001.jpg)
3. Name + Shooting date + Number OR
4. Shooting date + Name + Number
There isn't a provision for a time stamp naming convention.
To rename a group of images using one of the above naming schemes simply open ZoomBrowser and point it to the folder that contains the images you wish to rename. For this example let's assume it was your recent vacation photos.
I would utilize either Zoom or Scroll mode to view the images on the main screen. Then follow these steps:
1. Click the task panel labeled "View & Classify"
2. Next click the sub panel "Rename Multiple Files"
3. On the left hand panel click Step 1 "Select images"
[Here you can select any or all images in the folder]
4. Next click Step 2 "Specify Rename Settings"
5. Select the way you want the files to be named and enter
the appropriate settings. Note: If you wish to keep the original
file and make a copy with the new naming scheme make
sure you check "Make Copies of files"
6. Lastly click Finish and your newly renamed files will be there
in the folder.
Hopes this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Power Shot A520 upload a image to the computer
Dear binghau:
The surefire way to have the date show on your pictures is to set your camera's resolution to PostCard Mode and thus record the date stamp on the picture itself. Your ZoomBrowser software, however can put the date on each of your images. I am using ZoomBrowser EX ver 5.8 as an example. If yoiur version if different it will still have similar functionality.
You may choose to do either method 2 or 4 to get the date.
To rename selected images or a group of images using one of the above naming schemes simply open ZoomBrowser and point it to the folder that contains the images you wish to rename. For this example let's assume it was your recent vacation photos.
in the folder.
Hopes this helps.
Sincerely,
HeavyDLB
Apr 17, 2008 | Canon PowerShot A520 Digital Camera
Mixes up my songs
rename the files with numbers at the beginning, like 001, 002, etc - time-consuming, but effective
Mar 22, 2008 | SanDisk Sansa m230 MP3 Player
Casio FX-115ES Scientific Calculator Logo
26 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
