Question about Acer Aspire 3680 Laptop
Two grey blocks with sun like simbols in their center
Whilst trying to open Advance mode on my Aspire one ZG5, i caused two gray blocks to appear with a sun character in their center.When the control arrow is placed over one of them "New item, This item has not yet been configured" shows up besides it. Well the problem is they sit on top of all other windows and i cant trace my steps to find out what i did to make them appear, and i cant get rid of them! Please could you help me, i am new to Linux Linpux and still find navigating it a little daunting.
  • 1,602 Answers
CAN SHUT DOWN, UNPLUG AND REMOVE BATTERY, OR BOTH.
REBOOT AND START IN SAFE MODE
IF ON DESKTOP
CTRL-ALT-ESC ALL TOGETHER
THAN START CLOSING THE PROGRAM YOU WANT OR REBOOT THE WHOLE SYSTEM
CANDYMANGANDY
Posted on Feb 11, 2009
I cant enter sleep mode on my acer aspire one zg5. How do i fix?
Your settings in power mode have changed. Open up display and go to the screen saver tab (win 7) you will see the power savings option at the bottom. Go into that and change what the buttons do. You will have 3 situations to change. What happens when i close the lid, power button and sleep mode. Chances are you gave everything set to do nothing
Nov 22, 2015 | Acer Computers & Internet
Need help with my acer aspire one zg5 with linux os.... i cant connect to the internet and cant even open my network center and some icons disappeared. pls help
Hi, I may have a solution for this problem, but will need to verify some info first...is your model the AOA110 or the AOA150?
Jun 24, 2011 | Acer Aspire One PC Notebook
When i open my acer aspire one ZG5 the acer logo appears and then everything turns black. It doesnt reboot in saving mode either.
hi,
I have a video for you below courtesy of youtube to help you in your problem.
hope you have the same problem below and this might help you solve it.
Don't forget to rate me and thank you for using FixYa!
regards,
john
Jan 25, 2011 | Acer Computers & Internet
A horizontal gray bar splite the screen when I open my acer aspire one zg5
You could have a bad LCD- try connecting your laptop to an external monitor- if that image has no bar, then the issue is definitely your LCD. You can try purchasing a replacement if you are not in warranty direct or through Ebay, etc. However if you are in warranty, get it serviced.
Oct 23, 2010 | Computers & Internet
Acer aspire one model zg5 battery won't charge
I have exactly the same problem and am searching at the same time as you. I think you are wrong. I think the 150 is for the larger screen model. I think we need the 110.
I think it's this one that i found at acer-euro
ftp://ftp.work.acer-euro.com/netbook/aspire_one_110/bios/v.3309.zip
but I'm afraid to use it (which is not to say I know how). Somthing about putting it onto a USB drive and running scripts. At least that's what they do with this problem on a 150
Jun 29, 2009 | Acer Aspire One PC Notebook
Two grey blocks with a sun character in their center.
Its hard to tell because each version of Linux has its on special files that it can download. Look in all of your applications and see if you find a program called Synaptic Package. All you have to do is click on it and it goes to the repository and will update all of the packages and its dependent packages automatically. Not all versions have Synaptic, some just say Software manager, but its the same thing. So if you loaded Skype off of the Internet then you probably don't have all the files as Linux does not work like Windows. You can look for the Terminal window to open and type sudo apt-get install Skype see if that works, but again, if the program did not come from the specific repository then it may not update. If you want to remove it then you can either find it in your file manager program (again in applications) and delete it. Or you can try sudo apt-get remove Skype. Third option is to right-click on it and see what options you get if one says cut or delete then you know what to do. The sudo options will ask you for a password which you should have, its the root password. Last solution is to reload and start over, I've done that more than once :)..Well hope this helps, if you have any questions let me know.
Don't foget to rate this solution before logging out.
Jan 25, 2009 | Aspire Computers & Internet
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
HP Solution center for C6180 All-In-One opens but appears blank
Run HP solution center as administrator. This is a temporary fix; try upgrading or reinstalling for a proper solution.
Jan 01, 2009 | HP DeskJet F380 All-In-One Printer
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Grey icon; top righthand corner
It probably is a mode you are in, try switching your modes, is this the picture you are seeing up in the right, the gray icon?6719dfc.jpg
Nov 17, 2007 | Pentax Optio M10 Digital Camera
Acer Aspire 3680 Laptop Logo
93 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
