Nothing shows up on the screen when you hit the power button, not quite sure why. The little green light goes on and off though, so that means the power is fine... :S helllp please
mine does the same thing. does anybone know if it may bew a code that i accidentally set and it wont nont turn on without a password? is that even possible?
You can't post conmments that contain an email address.
Hi Bismi,
my PV-DM2792 behaves for last four days in the same way - double clicks when power button is depressed and the light PROG is flashing every second continously. I have called to the Panasonic customer service and they could not propose a solution to this problem other than contact an authorized dealer in my area.
SirJ
I have the same problem with the black screen and no sound. Also the green light turns on and off while hitting the power button. Although if i turn it on then off multiple times it eventually turns on and works perfect... Could you do the same thing before it finally quit all together or did yours just happen over night?
-Kenny
you can try and restore it. remember it will clear everything from your ipod but you can resync them later after restoration, to restore: make sure you have itunes running and have access to the internet.
hold down the power/sleep button and the home button at the same time, the ipod will go dark, once it goes dark release the power button while still holding down the home button, and itunes and a usb cable icon will show up.
you might have to do this several times before those icons show up since your screen does not even light up.
now connect the ipod to your computer and itunes should recognized the ipod and follow the instructions to restore your ipod. it will take some time but it worth the wait.
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
The same as above ,even my remote won,t work.
Try to change volume manually but nothing screen flashes no cassett.
Harold
