I want to replace power on/off pushbutton switch. Where the switch is available/
THE ABOVE MACHINE POWER ON/OFF SWITCH NEEDED TO REPLACE. FROM WHERE I CAN GET THE SWITCH/ & HOW MUCH IT COST/
  • Washing Mach... Master
  • 17,129 Answers
Please check for spares, click Washing machine spares
Posted on Jan 17, 2013
IB4G2008
  • 3587 Answers
SOURCE: Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Posted on Feb 27, 2008
dutchman05
  • 487 Answers
SOURCE: lid switch
You might have blown the fuse in the system
Please check following link
HERE for partnumber of the 10A fuse
Here for the diagram
Posted on May 01, 2008
  • 3 Answers
SOURCE: error code 43 on F& P washing machine
Carefully remove control console, then control board. Take note of which connector came from which terminal! Balance sensor is located under control board. Remove with care. Check that little button (size of pen top or pencil lead) is moving in & out freely. It is spring loaded. If it sticks, replace it. Hope this helps.
Posted on Jun 17, 2008
jmgldsmth
  • 1869 Answers
SOURCE: replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
Posted on May 29, 2009
  • 365 Answers
SOURCE: Lid switch replacement
Some washing machines have the bolts that hold the top down situated behind the front panel but you have to remove the panel to gain access.
There may be 3-4 screws at the bottom of the front panel, remove the screws and the panel should come out.
Hope this has helped
Posted on Jun 16, 2009
Power keeps turning off on Nilfisk vacuum
What kind of vacuum is this? If it is a pushbutton switch you may need to replace the switch.
Oct 24, 2013 | Nilfisk Family Vac Bagged Canister Vacuum
Tip
HP desktop power-supply LED lights, but system shuts off/hibernates during...
The "Problem" section below describes a startup problem my 9-year-old HP desktop developed last week. You may be seeing similar behavior in your HP desktop, or even in another brand. The "Solution" section describes a simple fix (cost: ------
Problem:
Our HP Pavilion a220n tries to start up but turns itself off or sometimes hibernates in the middle of booting up. Although I got it all the way to the login screen once, it then shut off again. It is not stable enough to use or to copy our files over to a new PC.
I've eliminated as causes the power supply and the AC cord. Because sideways pressure on the switch assembly can cause the problem, I assume I need to replace the switch. The faulty power switch is HP Part # 5187-2439 and includes a plunger microswitch, 2 LEDs, 12" cable and motherboard connector. The power switch assembly doesn't seem to be available from HP or third-party sources after 8-9 years -- big surprise!
The FixYa suggested solution with 2x5 motherboard pinouts is the beginning of a solution to my specific problem. Those pinouts do match the pinouts for my switch assembly. If generic power switch assemblies matching this pinout had been available, replacing the assembly would have solved my problem.
Solution:
SOLVED by replacing a noisy power-on/off pushbutton. Of course, you should observe all typical precautions to avoid electric shock to yourself or static discharge to PC internal circuit elements. Wearing a grounded wrist strap and touching the chassis metal to a grounded lead will help with this.
To start, you must remove the "bezel" (front panel) from the chassis after removing both side panels. Instructions for doing this are embossed on the plastic mounting flanges, and you can also access online instructions at the HP site. There's a small (about 1" by 2") plastic housing for the power switch, power-on LED, and disk-access LED, that you pop out from the chassis, making the switch contents accessible.
For convenience, I unplugged the 2-by-5 plug from the motherboard and worked on the switch assembly outside the chassis. To thread the plug and cabling out of the chassis requires removing the hard drive from its mounting bracket (no screws) and the mounting bracket itself (two screws). You may be able to do the repair without this step.
Then I verified with an ohmmeter that the original pushbutton was a single-pole, single-throw, normally open (SPST, NO) momentary switch, which closes the contact only as long as it is pushed in. It really had to be that type, considering that the switch has just two wires coming off it, and that depressing and holding the pushbutton has a different function from depressing and immediately releasing it. Checking with an ohmmeter also allowed me to verify that the switch was noisy (it intermittently closed when the plunger or housing was laterally stressed). These intermittent closures were causing the spurious hibernate events.
I bought an inexpensive replacement switch of the same type (in mini-pushbutton size, part 275-1547) at the local Radio Shack. As of today (6/16/2012) it is listed online at "http://www.radioshack.com/product/index.jsp?productId=2062539". Although the online site says it is rated at 0.5 A, the package says 3.0 A at 125 V. Any other similar switch would do as well.
In my HP model (HP Pavilion a220n), the pushbutton lives in a square hole in the 1" by 2" switch/LED mounting piece mentioned above. It is easily poked out with a pointed soldering tool or nut pick. I unsoldered the red/black wire pair and soldered them to the new switch. The small size of the mini-pushbutton allowed it to fit partway through the 1" by 2" switch/LED mounting piece. That allowed me to remount the front panel to the chassis (minus the round power-on/off cap with the power logo on it -- which was broken in my case anyway), leaving the pushbutton available for use.
on Jun 17, 2012 | HP Computers & Internet
Replacement part for HP Pavilion a220n switch?
why guess, why not say power problems and leave it like that.
simple,
bah you can buy used part for HP of ebay all day long
but why, first find cause. but that switch stock , oh boy../
that case switch is just a SPST norm. open momentary switch
you can remove it and jump test the wires easy.
super easy test. if the powersupply over loads it turns its self off
the
the logic takes over after that, that simple switch is just momentary,
dig?
first first off say its a DESK tOP, ok? so others dont need to look it up or guess wrong, some here (kids) never seen one ever.
"its a brave new world" no?
wow a year 2000 desk top 17 years old, and almost runs
take a photo and frame it
has a value of what $5 or as seen in deep racks of goodwill
nobody wants. endless used ones parked in attics.
or sent to 3rd world as gifts but i digress.
path of logic
switch momentary
MOBO sees that and with gates, turns on the PSU.
the PSU comes up, and if not overloaded
the PCU sends PowOK signal to mobo
and mobo holds up power.
they work as team , logically
and if the MOBO sees shutdown from windows
it can reverse that gate logic and shut off.
as we all see every day.
bad PSU can shut down if bad. all can, psu bad
or if the overload is real. by ATX design.
SOME mobo can to for other reasons
like fans dead, or CPU overheated.
my top tier, ASUS mobo does All that and more.
even has a tamper switch, option.... full features in mine.
some pSu can shut down for dead fan or overheat or both.
mine can , i use high end PSU.
what is inside the HP, mobo is anyones guess
they dont publish to that level, like mine is..... and why I build all my systems(DT)
so when working any DT keep all that in mind
its not as simple as most think, it seems
the switch is just a REQUEST for power.
or if pushed 2 times, the reverse, but is programmable THAT..
here is my 2 power pins
on the mobo (not yours)
i unplug the pwrsw jack
i short the 2 pins, there,
power stays on my switch is bad. EASY NO?
oddly the last line in your post solve it.
a generic switch, momentary.
but you can do that with 2 ***** wires in hand
if ok switch bad.
if not ok , not the switch,, 5min work.
Mar 02, 2017 | HP Computers & Internet
I installed Leviton 2591 switch (to replace a broken one). The switch is supposed to be "off" when untouched and "on" when held pressed down. My switch is behaving opposite. It is...
You have installed a "Normally Closed" (NC) pushbutton. You should replace it with a "Normally Open" (NO) pushbutton, sometimes called a "momentary" switch.
Jun 21, 2011 | Leviton Single Pole Pushbutton Switch -...
Robinar Cooltech 342000 - on start up stops on the "Initalizing System" screen. Is there a reset procedure available?
You can try the following : 1# Check main 15 amp circuit breaker (located on back of the machine), reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
2# Verify line voltage is present at input of main power switch & output at switch turn ON. If line voltage is not present at power switch input, check connections between power switch and AC plug. If line voltage is present at power switch input, but not at output with power switch turned ON, replace power switch.
3# If all proceeding steps tested OK & problem still exist, you may nee to replace The main control module.
Hope this will help you, if so please vote for it.
Mar 07, 2011 | Robinair Cool Tech 34700Z Recovery,...
No power or signs of power
check the power going to the machined,
check the fuse or circuit breaker.
check selector switch or pushbutton switch.
Jun 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
It wont power on?
It's probably the capacitor, or the pushbutton energizer.
It's really easy to dis-assemble this unit, and it works really well for a $100 night vision scope.
You can replace the pushbutton with a toggle switch from Radio Shack.
Dec 01, 2009 | Kalinka Cyclop 1-V (NZT-1M2) Wide Angle...
How to take ups in manual bypass mode.
You definitely want to follow the manual procedure to avoid a possible load loss:
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/9390.aspx?cx=3
9.1.4 Transfer from Normal to Bypass Mode
To transfer the critical load to Bypass mode:
C A U T I O N
In Bypass mode, the critical load is not protected from commercial power interruptions and abnormalities.
1. Press the CONTROLS pushbutton on the main menu bar. The System Controls
screen appears.
2. Press the BYPASS pushbutton on the System Controls menu bar.
The UPS transfers to Bypass mode and the critical load is immediately supplied
by the bypass source. If the bypass source is not available, the power processor
remains on and an alarm sounds.
3. The UPS is now operating in Bypass mode and the BYPASS status indicator is
illuminated.
The power module (PM) status indicates READY. The system is now on bypass
and the UPS power processor remains on.
At this point, you can operate an external bypass switch to get to maintenance bypass if needed.
Oct 14, 2009 | Eaton PW9390 UPS System
No power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Jan 20, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
OSD Main Menu
because of moiture pushbutton switch were conduct there for replace pushbutton switch and see result
Aug 15, 2008 | HP Pavilion F1703 17" LCD Monitor
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
