Question about RCA P52937 52" Rear Projection Television
Television has no picture
Our tv has no picture but perfect sound. It has red, blue, green line(thin) across the screen about eight inches from the bottom of the screen.
  • sarahl66 Feb 24, 2008
    Television has black screen with bright horizontal line across the middle of the screen, sound seems to be okay.
  • Anonymous Mar 31, 2014
    remainder of picture ok
  • 398 Answers
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Posted on Jul 13, 2007
6ya staff
SOURCE:
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Projection lights don't line up
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Lines on the screen
Are they thin, white lines running east to west? If so, they are called retrace lines and indicate that the screen settings for the picture tubes is set too high or there may be a mal-function of the CRT driver circuitry. Try adjusting the screen controls which are located behind the front grill of the TV behind an access panel. Once you remove the grill and access panel, you'll see a small control assembly the has two sets of controls. Three for adjusting the red, green, and blue focus, the other, the red, blue, and green screen controls. To adjust correctly, put the TV on an unused input(dark, blank picture) and adjust until there are no visable retrace lines or color in the image.
michtech
Feb 14, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
RCA P52937 52" Rear Projection Television Logo
220 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
