Question about Posiflex CASH DRAWER PRINTER DRIVEN DRAWER CR6000 1685 X 1811 X 394 B
Possiflex cash register drawer jammed - Posiflex CASH DRAWER PRINTER DRIVEN DRAWER CR6000 1685 X 1811 X 394 B
Why won't the cash compartment open?
number of reasons possible
check paper if it prints out a receipt each time. Have seen this occur in Fast Food store. Cash register would not open.
If you can get the drawer out check behind drawer for foreign objects.
Check coins are not jamming drawer
could be a faulty solenoid that pulls lever to electronically open drawer.
Dec 31, 2015 | Retail Supplies
Cash register casio tk 2300 not opening
If you can finish a sale but the drawer does not open, check the wires that come from the bottom of the register to the drawer. If one has broken or the plug has disconnected from the drawer, it will not open.
Nov 02, 2015 | Casio Parts Cash Register PC Desktop
I cannot close the drawer on my sharp xe-a102 cash register
either something is getting in the way of the drawer clip
the under neath pull drawer open by pass is jammed
some plastic has broken or a clip interlock
you need to take the drawer out and examine it all carefully for broken bits
contact the local sharp agent and ask for detail
or even pass it too them for service
Dec 03, 2014 | Retail Supplies
How can I get a replacement key for the lock on the drawer?
cash register drawer keys usually can only be purchased from drawer manufacturers...it all depends on who makes it, mmf casio apg samsung etc
Oct 09, 2014 | Royal Cash Register 500dx
I have a Samsung SER 6500 II cash register is locked on the error code ERR PRT. I have checked the ribbon and receipt feed area. Nothing blocking it...I've done an intial clear to no avail.
Sounds like you have printer failure. Have you tried flicking the lever under the drawer between the back two feet to open it?
If anyone is having problems with Programming on the Samsung SER-6500II cash register, the manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Samsung3.php
Sep 03, 2012 | Casio Parts Cash Register PC Desktop
For cash register casio TE-100 can't open
As long as you are able to complete the sale normally (or use the no sale function), the problem is usually due to a locked cash drawer or something jamming the plastic insert inside the drawer.
If anyone needs more information, the Casio TE-100 manuals are here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
May 22, 2012 | Casio Parts Cash Register PC Desktop
Cannot open register casio pcr-265p model pcr-265p
Hi. It has nothing to do with button pressing.
The machine is indicating printer failure. make sure nothing is jammed in the printer.
Mark
Dec 24, 2008 | Casio Parts Cash Register PC Desktop
Casio CE-2300 Cash Register
Hi.
It sounds like a hardware problem, not programming. I would look at the drawer latch mechanism in the back of the drawer. Check the wiring to the solenoid (metal block in the back of the drawer). Make sure the drawer can be opened with the trigger underneath - this will tell you if the insert is jamming it, or the mechanics of the drawer are the problem. Apart from that, it is usually a drive fault in the electronics. Since this model is dying off rapidly now (the printers were a bad design by Epson), I wouldn't spend too much on it if I was you.
Mark
Nov 07, 2008 | Casio Parts Cash Register PC Desktop
Posiflex CASH DRAWER PRINTER DRIVEN DRAWER CR6000 1685 X 1811 X 394 B Logo
Top Posiflex Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Posiflex Office Equipment and Supply Expert? Answer questions, earn points and help others
