How do I programme a sector SV7TC
Change the setting
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
Red lock sign, machine wont start
interlock faulty and should verify that the electronic module should also be spoiled in this sector. Probably a blown triac.
Dec 22, 2013 | Washing Machines
Need to set time on 1500e lathem
Hello
To enter the programme setting mode, you should plug the AC adapter to AC outlet and remove the cover. Thereafter press 'Select' button once. The the clock goes into the programme mode showing "UP Arrow" on the display positioned at "Time"
Function of three control buttons.
'SELECT": You can select the desired programme setting modes by pressing "Select" buton. Selected programme setting mode is indicated by the "upward arrow" mark on the display.
"CHANGE": When you press "Change" button, you can increment the set value.
"SET": You can set the value selected on the display by pressing the "Set" button. Thereafter you press this 'Set" button again, you can return the clock to normal operation mode. OK.
Dec 14, 2011 | Audio Players & Recorders
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    How do I change the cooling fans to kick on sooner than they do? I live in the desert and its very hot! I put in a new thermostat which is better suited for my climate...but how do I get the fans to kick...
    The only fix I have found besides adding a switch to the common terminal of the fan relay, and a ground, is to pick up the following ECU programmer from Corvette Central:
    Click Here
    Hypertech's Max Energy Programmer allows you to set engine cooling fan on/off settings, set top-speed limiter, engine RPM "Rev" limiter and even transmission shift points and firmness. Hypertech's Corvette Max Energy Programmers also allow you to return to stock settings or change settings anytime. Have you changed your tire and wheel size or differential, if so, and then you can make your speedometer corrections by using Hypertech's Max Energy Programmer.
    It costs around $400 bucks, so definitely not a cheap fix, but it is a better fix.
    Jul 17, 2010 | 2004 Chevrolet Corvette
    How do i get the temerature guage to work on the secto mountain master? I recently purchased a Sector Mountain master 4 days ago. I have been reading the instruction manual over and over and I have yet to...
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SECTOR watch manuals and these may differ from yours.Rate me, please.
    Mar 25, 2010 | Sector 3251908015 Mountain Master watch
    Hard drive bad sector recoganisation
    To check for errors and bad sectors on a hard drive, open My Computer,>right -click on the drive(for example D disk)>select Properties>select Tools tab>click on Check for errors button.
    Apr 25, 2009 | ASUS P5PE-VM Motherboard
    I want to restore factory settings on my laptop
    You could try a system restore to the day before the changes, go to accesories,system tools, system restore. The programmes should be there again but may not work correctly it's a fingers crossed job. The only other way to restore is if you have a restore partition on your hardrive or a restore disc, but normally there would be a programme built in to restore the notebook to factory settings.
    Sep 03, 2007 | Toshiba Satellite P105-S6207 Laptop
    Computers & Internet Logo
    109 people viewed this question
    David Payne
    David Payne
