Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Not picking up water on a bissel proheat turbo 2x
When I turn the dial to normal and wet the carpet I assume the water should be picked up when I am not pulling the button and am moving the vacuum toward me. When I finished there is NO dirty water in the tank (thus why I think the machine in not pulling the water out). Do I have to use the rinse cycle as well and if so, is this when the dirty water is removed from the carpet? Thanks
  • 7 more comments
  • satin442002 Feb 04, 2009
    I have the same problem the water will not **** up what do I do
  • kami907 Feb 28, 2009
    I have the same problem but I think that the water and cleaning product are comming out on to the carpet.
  • Anonymous Mar 14, 2009
    Everything work just fine until to get ready to **** up the water there is no suction it seem to be clogged. How do you unclog this steam cleaner?
  • Anonymous Mar 18, 2009
    I have the same problem. Worked fine for years and now won't pick up the water.
  • Anonymous Apr 06, 2009
    We have The Pro Heat Turbo x2 does not sucktion water off surface, we has have it for several years but had hoped it would work for many more yrs.
  • mandalone Apr 27, 2009
    Same Problem. Not picking up the dirt. No dirty water at all. Any solutions at all?
  • tammyhenshaw
    tammyhenshaw Feb 20, 2013
    i cant find the red filter
  • Richard Starr Aug 12, 2017
    I've experienced that if these things get hot, like from being stored in the garage, the tank can walk and you lose the seal.
    Should say warp, not walk
If unit is not picking up solution it is most likely the small red plastic filter that is just above the small float door in the top piece just left of the tool switch.. pop it out clean muck out of it and it will work like new again.. have fun!!
Posted on Jan 31, 2010
  • 5 more comments
  • Tony Dec 12, 2010
    IF THE RED FILTER CLEANING DOES NOT WORK, THERE IS LINT CLOGGING THE PASSAGE AROUND THE DIAL THAT YOU CHANGE FROM TOOL TO FLOOR CLEANING. YOU WILL NEED TO FLUSH IT OUT BY RUNNING HOT WATER THROUGHT IT WHILE TURNING THE DIAL AND SHAKING VIGOROUSLY ON OCCASION UNTIL THE LINT FLUSHES OUT. GOOD LUCK.
  • LadyC1 Jun 13, 2011
    THANK YOU! THANK YOU! THANK YOU! Yeeeeeee Haaaaaaaah!!! I have looked through site after site after site and this is the most helpful! Yes,I found the little red small plastic filter,cleaned it out and it sucked up water like a champ! Thanks again to gmost for your expertise. LadyC
  • housewife721 Aug 07, 2011
    Omg Omg, thank u thank u thank, u just saved me so much money n time, I've cleaned every possible part, took stuff apart n then I gave up, I finally said duh do some research n came across this, ur absolutely a life saver n my husband says thanks for saving him 260 dollars for a new one plus rentals!!!
  • sulywaan
    sulywaan Jul 13, 2012
    yay...it worked it fixed it but I have a Proheat 2x and there was a little red flap inside the water tank that had just enough lint. Thank you thank you!!
  • Ron Dilger Nov 06, 2012
    THANK YOU! I never knew that filter was there. A 3 cent piece of plastic...
  • Tracey Nov 04, 2016
    Where is the red filter located so i can clean it
    Please show me pic i think i dont have a filter to clean
We had this problem last night - checked the belt, cleaned the brushes, etc. It worked fine on sucking up with the hand tools, but would only **** up with the vaccuum part when the unit was in the upright position standing still - i.e, when we would tilt back to begin moving forwarding the suction would stop.
The user guide doesn't tell you this part in the trouble shooting section.........
The red door thing - that supposedly closes when the tank is full, or if the unit has hit/knocked into something, actually has a filter on it.........the filter had a bunch of debris in it..........we cleaned the filter and the machine is back to working like a charm!
Posted on Jul 25, 2009
  • Tony Dec 12, 2010
  • paula x
    paula x Apr 29, 2017
    Its not sucking up water bcuz the tank is not sitting on that black seal properly... If u push down on the tank u will see the water began to come up move ur hand it will stop flowing... Your welcome ;)
Posted on Aug 07, 2011
  • Teri Everhart
    Teri Everhart Feb 23, 2014
    Same as above ...,I didn't know what else to do! This is a great machine and I thought it was broken. So very grateful for online help!
Posted on Feb 14, 2009
  • Tony Dec 12, 2010
We tried the above solutions, and although helpful, they still didn't solve the problem. Then we took off the clear shield that surrounds the tools/floor switch and reseated it more carefully, then screwed it back down. That did the trick! Suction was being lost there because after removing that plastic piece to clean it, we did not re-seat it well. Hope this helps!
Posted on Jun 22, 2012
  • Audrey Maes
    Audrey Maes Jun 10, 2017
    thank you so very much. got sick of the little red thing.
Cleaning the screen by the little red float door worked for us! Thanks for the suggestion!
Posted on Aug 15, 2012
I have a different problem where there is no suction with the tool attachment.
Posted on Jun 06, 2013
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: bissell proheat turbo 2x is dumping dirty water onto carpets.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
efdy
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
heatman101
  • 43501 Answers
SOURCE: Bissell Proheat 2x TurboDoes not pick up the water after cleaning
heatman101
m,nb
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Posted on Sep 04, 2010
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
May 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Too much solution being dispensed--carpets very wet--running out of solution before even 1/3 of room cleaned
The cleaning solution tank is only sufficient for part of a room, unless the room is very small.
Are you following the instructions for using the cleaner carefully? The machine has to be pulled backwards (towards you) at a steady pace in order for the vacuum to pick up the water that is dispensed. Do not use it like a normal vacuum cleaner - that will not work.
You need to start facing a wall, and pull the cleaner towards you, moving at about one foot every two or three seconds. The vacuum will then pick up the water that has been dispensed and the carpet will be damp but not sodden.
Apr 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pet hair and dirty water back on carpet
If you have followed the instructions.And your not happy i would return it.Get a repacement.
Aug 08, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The water is staying in carpets and is not being sucked back to the machine
The pick up slot across the front of the unit may be blocked or internal path for the water into the tank. Disconnect from electric and strip down the head and check for fibres/fluff balls - as these are the normal culprits. I am assuming that the suction motor is running?
Good luck
May 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
heatman101
789iut
Nov 20, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
heatman101
m,nb
The water swirts ou put the vacuum does not pick up the water
Make sure that you are using the wet hose and that it's not clog and hooked up tight to the hole in the front of the vacuum.The same place that you would hook it up to vacuum.
Dec 02, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
22,732 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
