Question about Gaggia MM Electric Burr Grinder
Gaggia mm coffee grinder makes awful noise.
As you adjust to the finer settings the grinder makes awful grating noises. This unit is brand new! No grating in the courser settings.
  • 833 Answers
SOURCE: Broken Handle on Coffee Grinder
Nice unit! Replace the part. Try www.smallappliance.com.
If you want to try to glue it first, get a product from 3 M. I think they call it super strength glue. Scrape off all traces of whatever you used before. Follow the instructions exactly.
Posted on Dec 03, 2007
mirran
  • 515 Answers
SOURCE: gaggia coffee
Do you prime the machine when you connect it to power?
Posted on Jul 17, 2008
SOURCE: how can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Posted on Feb 12, 2010
  • 1089 Answers
SOURCE: how do you adjust the size of grind with a gaggia
The is a little lever you push up by the bean hopper. Then rotate the bean hopper to change the grind.
Posted on Apr 20, 2010
z34aga
  • 137 Answers
SOURCE: how do you change the grind on a gaggia coffee
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Posted on Feb 21, 2011
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Coffee weak
warm up well before brewing coffee and set the grinder for finer coffee powder
Jan 19, 2016 | Gaggia Titanium Espresso Machine
Which setting gives a stronger brew, setting 1 or setting 10 on the grinder.? There is a setting on the side door, what does this control?
Hi On this machine you want the lever under the grinder on 4 and the lever in the middle of the door towards the + (plus) but not all the way. Back 1 mark is the strongest setting you should use. It puts more coffee in the brew unit, there for stronger. If push all the way you will get an over charge on some shots and you could also break the brew drive. The grinder lever can be moved to 3 but only when the grinder is running. This makes the grind finer (smaller #'s). Get it too fine and you will plug up the brew unit.
Jun 06, 2011 | Gaggia Syncrony Espresso Machine
My baby gaggia is putting out water too fast resulting in weak coffee.
Adjust the coffee grinder to finer. (coffee grounds are too coarse)
Jan 17, 2011 | Gaggia Baby Espresso Machine
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
How do I adjust the grinder to make the coffee grind finer? ie. the coffee is pouring way too fast and giving no crema.
Depending on the model and make on the grinder you just have to turn the adjustment collar clockwise for finer, that is the case with most grinders.
Nov 11, 2009 | Coffee Makers & Espresso Machines
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Problem with tamping
Try adjusting the grind to a finer setting also the amount of coffee can be adjusted with the lever in the grinder chamber.
May 06, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia coffee
Feb 01, 2008 | Gaggia Coffee In White, White MDF...
Gaggia MM Electric Burr Grinder Logo
26 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
