Question about Sony STR-DE197 Receiver
Protect? Recently while playing a device on CD or MD/Tape the reciever will stop playing and the word "protect" appears in the display. What does this mean?
  • 432 Answers
Overload protection circuit kicked in. Check all your wires (speakers,input,output cables), There is a short somewhere and lets hope it's not In the receiver.
Posted on Jul 12, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
Jan 27, 2014 | Yamaha HTR-5840 Receiver
My cd/md player says "protect"
Most MD players have a HOLD button to prevent the player from turning on accidentally in your pocket.
Find it and make sure it is off.
Apr 14, 2013 | Yamaha Audio Players & Recorders
Tascam MD CD1 MK2 / TOC Reading on my cd drive
I would consult New Jersey Factory Service- It sound like you might need a new CD module. Russ can tell you about those.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
www.njfactoryservice.com
Dec 01, 2012 | Audio Players & Recorders
How do I link my technics ge 70 graphic equaliser to my technics cd player sl-pd7a and my technics md player sj-md100 with phono rca leads . Thank you Simon
It would help to know what other electronics (receiver, maybe?) is involved.
If neither of those devices is a recorder, why do you need to connect them to the EQ when your receiver/preamp may have the facilities to connect the two playback devices directly; and the EQ in a Tape Loop?
Scenario A)
Assuming you REALLY want to have the CD and MD input through the EQ because you can't attach them any other way...
CD audio OUT to Line In; MD audio OUT to Playback;
EQ LINE OUT to whatever analog electronic inout you have in mind.
To hear and Equalize the CD set the Input Selector to Source, EQ REC button OFF; to hear the MD equalized set the Input Selector to Tape, EQ REC button OFF.
Scenario B:
You have a receiver with only ONE Line Level Aux input and a Tape Loop.
Insert the EQ in the Tape Loop. Attach one of the disc players to AUX and the other to the TAPE conenctions on the EQ.
Scenario C
You have a Home Theater System or Audio Vido Reciever.
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 01, 2011 | Technics Audio Players & Recorders
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
How do you switch between the front aux and the line in on the back of unit
According to the manual:
"In the case of a CD/MD changer or SAT tuner being connected: when "source" is pressed the connected device (MD, XM, or SR) will appear in the display, depending on which device is connected. Then if "MODE" is pushed you can switch the changer or change the SAT tuner band."
Mar 24, 2009 | Sony CDX-GT520 FM / AM Receiver
Equalizer for Bose 901 Series IV
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's attached as you have them will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to receive its Active Equalization and for another, if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devises for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what I think you're trying to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). Yours does NOT so we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious place would be at one of the few OUTputs on the back, assuming you have one free to use.
I see Video 1 and MD/Tape have Audio Outputs. Use one of these to feed the Bose EQ. **
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Sony STR-DE595 (Video 1 or MD/Tape Audio Out ***) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receivers speaker level setup.
*** In either case you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. This is what's happening to you right now when you select MD/Tape. You're disconnecting the source from the 901 EQ.
You may have to get ugly with your other input components to find them all homes on the receiver. The labeling won't necessarily match up with the device types. Mine is ugly like that and I have a lot of connectors, but I have even more input devices.
If you have CD, TV Cable box and DVD (typical) you need to assess what you have that is digital and use what you can wherever you can, then the leftover analog device(s) - PC? - can go into any available analog input that is left over.
Whichever of these connections you DO NOT use for the 901's will still be available for using some kind of conventional analog recording device or sound processor such as an EQ or dbx Expander. However, as with any digital receiver, selection of that device for monitoring will kill the sound from any DIGITAL source you have playing (or maybe it just won't allow you to monitor).
Jan 17, 2008 | Sony STR-DE595 Receiver
Sony Net MD Walkman (MZ-N910)
had the same problem a few minutes ago!
removed the battery but it didn't help.
tried with another md, no success
tried the same md in another Mz 910, no success
then it got on my nerves and I gave the MZ n910 a little shock with my hand.
It worked, stopped spinning and started to play.
It was, I think, a spinning problem, md couldn't play properly, the little shock helped.
Apr 09, 2007 | Sony Net MD Walkman MZ-N910 Portable...
System keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Nov 17, 2006 | JVC MX-K30 CD Shelf System
Sony STR-DE197 Receiver Logo
523 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
