Question about Epson 9880 stylus pro Printer
0001002D - Cleaning Unit end of life (Reset When Cleaning Unit Change)(Pump Assy, Pump Motor, Cap Assy, Wiper Blade, Flushing Box).
I have a copier machine canon ir 2420l. Drum is fine yet the copy quality is not clear in the edge.
Dear
Pl. check the counter and life of the drum unit. If refilled toner (other than genuine ) dis-assembly the drum clean the wiper blade and warm up the drum using dry Cotton. Also check the developer assy. for even flow of toner.
Thanks.
Jan 02, 2015 | Office Equipment & Supplies
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Driver's side windshield wiper goes past window frame. How can this be repaired?
It could be a relatively easy fix or it could take some effort. First, try repositioning the wiper. By flipping up the end cap of the wiper arm and backing off the set screw that holds it on the wiper motor post. Remember, what position it was in by placing a piece of tape on the windshield. Pull the wiper arm off by pulling it off in line ith the angle of the wiper motor post. Take a close look at the splines of both the wiper blade arm and wiper motor. If either is damaged you will have to replace that component. Estimate the amount of adjustment you need and reinstall the wiper blade arm that amount in relationship to the piece of tape. Tighten set screw and try it.
If it still does it but less then repeat the process until you get it adjusted correctly. If there was no change thing it could be the wiper motor and that takes some effort to replace.
Nov 30, 2011 | 2001 Jeep Cherokee
Error code 0001002D is displayed and can not clear
Thank you for the inquiry.
This usually is a Epson Large Format printer error. You will need to replace parts to clear.
blank.gif headerline.jpg header.jpg epson_loyality.gif blank.gif menu_background_l.gif home_off.gifseparator.gifcoveragearea_off.gifseparator.gifservices_off.gifseparator.gifprinters_off.gifseparator.giftechnical_off.gifseparator.gifsearch_off.gifseparator.gifenquiries_off.gifseparator_r.gif menu_background_r.gif blank.gif 0001002D Cleaning unit EOL
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
worn_flushing_box.jpg worn_cap_assembly.jpg Worn flushing box Worn cap assembly worn_head_wiper.jpg worn_carriage_waste_pad.jpg Worn head wiper Worn carriage waste pad
Jun 03, 2011 | Office Equipment & Supplies
The rear window wiper blade holder is rusted how do I remove it for replacement?
Three things you can replace depend on your budet
1) you can replace whole wiper blabe assembly by lift up the cover at the bottom end of the bale assembly and un-screw the nut and raplace whole assembly with arm , wiper insert etc ... with the new one This way cost you more.
2) on hte middle of the whole wiper blade assy has the flexible section, you can un-screw 2 small philipe pan head screw with screw driver and disconnect the top section with the wiper blade insert (rubber)
3) slide wiper blade insert out of the holder, becareful with 2 small steel blade will hole your rubber insert inside the wiper frame. Slide new rubber insert in the frame .
Feb 25, 2011 | 1995 Toyota Supra
Pson styllus pro 7800 service call error 0001002d.. help
this error 0001002D means Cleaning Unit end of life
The only fix for this problem is you have to call Epson and state them that you are facing this problem. They will provide you the codes to unlock this error. Its a universal solution that only Epson can provide you these unlock codes and you cant find in any websites.So contact them and get your problem fixed soon.
techbelkin
Dec 28, 2010 | Epson Stylus Pro 7800 InkJet Printer
Windshield wiper not moving.motor works.wiper was iced up,turned them on and they started to move then popped.wiper motor works and wipers seem to move a little.
open the hood and at the base of the wiper arm is a little balck cap, remove this cap and under it is a nut. this nut holds the wiper arm tight onto a spline. check to see if the nut has backed off or needs to be tightened. if not remove the nut and take off the wipers, the black cowel (at the bottom of the windshield) is held on with three plugs.(one in the middle and one on each end.) and one large plug below the passanger wiper blade. the wiper assembly and motor is under this cowel.
hope this helps
Jan 30, 2010 | 1997 Pontiac Bonneville
How to remove and replace the wiper blades on an 06 Murano
Me again. After looking at the blade for 15 minutes or so I did the following. Remove the wiper blade from vehicle (makes it easier to work on). There is a little tab under the blade near the end of the wiper blade arm. Press it and slide/pull the wiper blade toward you. Now when you look at the wiper it seems like its a sealed unit. Check the ends and you will see the rubber is flexibe enough to allow you to slid the "wiper" out ot the blade. You can get the replacement refill (the wiper) or a replacement wiper blade (the whole unit) from the Nissan dealer. Take the refill and slide into the blade assembly. Take your time. You might have to straighten the blade a little so that the refile lines up with the holding tabs in the blade. Looks impossible, but once you've done it you'll be surprised how simple it was to do......****
Dec 21, 2009 | 2006 Nissan Murano
REQ 0001002D
This is the result from running the machine with the maintenance code of 40 for too long (needs service parts replaced including pump cap assy and then reset counters). I have all you need (full maint manual, reset software and parts) if you need them. doadhe@gmail.com
Jul 04, 2009 | Epson Stylus Pro 7600 InkJet Printer
Ineed to know how to change the wiper arm
pull wiper up off screen and place a sheet of ply or cardboard on screen in case it flicks down with no blade on end of arm.holding blade /arm assembly turn blade horizontal to arm then push down on bottom of the plastic clip on the end of the arm at the end of the U piece and slide down towards bottom then when free push whole thing up at an angle to clear the U on the end of the arm.shouldnt take more than a minute to do.takes longer to write about it happy new year
Dec 27, 2008 | 1995 Ford Explorer
Epson 9880 stylus pro Printer Logo
286 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
