Question about Whirlpool RBD245PR Oven
Have bottom oven door on Whirlpool RBD245PRS0 problem
Was putting the doors back on the oven, top went on OK, bottom both went in, the left did not lock, the right locked. The left is loose where you can see all of the latch. Have not forced anything and have tied door so will not hang. Been unable to get it unlock on the right and the left will not go in. This is a built in oven.
THANKS George
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll need to pull the door back off, and "spring load lock" the left hinge and try again, youll never getit back on if one side is not in locked position. itll be tricky, but there no way around it
Posted on Jan 25, 2009
THE OVEN WAS ON AND THE BREAKER WENT OFF, NOW THE OVEN IS DEAD. THE BUTTONS ON THE PAL DO NOT WORK. THE PANEL I LOOSE.
Okay this doesn't make sense did the breaker trip if so look for a short to ground I have serviced many of wall ovens in self clean the TOD does trip do you have a display if not the thermal cavity fuse is open if it stopped in self clean the door is locked as a tech I went to the auto store and bought some feeler gauges use one at the top of the door in the middle slide gauge between door and body push to the left to release the catch door should open
Jul 30, 2014 | Whirlpool RBD305PD Electric Double Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven Was Self Cleaning. Bottom Oven Opens Top Oven Does NOt
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 21, 2010 | Whirlpool RBD305PD Electric Double Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whilpool Double Electric Oven has NO POWER
I had the same problem the first time I used the cleaning cycle. The oven was under warranty when it occurred so I watched the repairman when he fixed it. He not only installed a larger fan, but he had to replace a thermocouple that is on the back of the oven, part number 4450934. The oven seems to die (lose power) after every cleaning cycle. I'm now ordering my third thermocouple. To replace the part, you have to pull the oven out from the wall to access the back. To do that, open the oven door. (If your door is locked because of the cleaning cycle, you may have to take a hacksaw blade to slip it in to see if you can trip the latch. The repair man was lucky when he did mine as the door clicked open when he was just messing with it so I don't know any trick to get it unlocked. He said that because the thermocouple died, it didn't provide the signal to unlatch the door, so the oven thinks it's still at 500 degrees and keeps the door locked which is part of the safety process). If you do get the door open, on the sides of the oven itself, at the bottom inside hinge of the door, you will see a screw holding the molding (frames the side of the opening of the stove). Remove each screw (left side and right side at the bottom) and pull the molding off. You now have access to the screws that hold the oven to the cabinet that it is sitting in. Remove those screws (mine has one on each side) and you can then slide the oven out. It's heavy so you will need help or have some thing you can slide it on to. It needs to come out far enough so you can access the back. You will see the thermocouple on the back, held on with two screws. Remove the wires and take the part off and throw it away (or keep it so you know what to order again next time as you will be replacing it again after you do another cleaning cycle) GREAT WHIRLPOOL PRODUCT. Reverse the process and you will be baking in no time.
I
Nov 03, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
Can Get Door Back On
Just managed to put the doors on. Do the bottom door first. There are 2 little spikes on the bottom of the door. You need to slot them into the holes in the frame. Then make sure that the little metal flaps on the top of the door fit UNDERNEATH the inner door frame. Screw together.
Same with the top door, additionally add the trim on top.
Thanks to solution #1 - I've literally been fuffing about since yesterday evening, I was about to call out the engineer! :)
Jul 19, 2008 | Electrolux ICON Designer E30SO75ESS Oven
I have a Whirlpool Oven #SF395LEE* (RB26126336) accubake Systems. Today the oven door came off and I need to know how to put it back on. I do not see this over on your list. Can you help? Thank...
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 13, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirpool Super Capacity 465 Self-Cleaning Gas Range error code F5
facing the front of the oven (while off) put your hand along the back of the oven toward the top left side. there should be a techinical spec sheet with a list of what the codes mean and possable solutions.
Mar 08, 2008 | Whirlpool SB160PEE Gas Single Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Whirlpool RBD245PR Oven Logo
127 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
