9370 ic pin voltage - Televison & Video
4 Suggested Answers
SOURCE: TELEVISION CHASIS HAVING TDA 9370 SINGLE IC
Try zener from abl.
Posted on Sep 13, 2010
ercupa190
  • 12223 Answers
SOURCE: Lg tv ic 9370 vertical line and no rastar &
no raster sympton is rectifier faulty 2) filter leake 3) regulato ic faulty repair.
God bless you
Posted on Jul 11, 2013
gopakumarg43
  • 74136 Answers
SOURCE: What's your question? AKAI '21' TV PROCCER IC TDA 9370 -313B. WHAT LOT NUMBER
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "brand name" or the number of "Chroma IC Jungle" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 14, 2016
No raster but display and sound ok on lg 21 crt with ic 9370...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Jul 27, 2014 | Televison & Video
Tda 9370
Check the video output RGB out terminals of the TDA9370. Check the voltages. If can, check signal waveform. You have't specified nothing about the audio status. If you wish to get the schematic of TVs, using TDA9370, check the site linked here. Never confirm that the IC is OK. Check the serial data & serial clock. Replace the main system control memory IC, too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 21, 2013 | Televison & Video
Lg tv ic 9370 vertical line and no rastar & retrace what i do ?
God bless you
Jul 11, 2013 | Televison & Video
Service code for vediocon tv usig IC TDA9370ps/1932
WE WANT VIDEOCON CTV IC 9370PS SERVICING REMOTE CODE
Mar 13, 2012 | Televison & Video
My Panasonic TC-21Z88RBN doesn’t displays the total picture vertically ,when the picture is display it like not in the center of the screen sum of it is disappear in the bottom
Hello
Your TVs vertical output section has the fault. You just open your TV after disconnecting it from the AC mains wall socket, and locate the vertical output section. This section uses an Ic marked as part [IC 401] on the board and its number is LA7840. Just look for any loose soderings around its components legs, and the solderings at the IC legs, which has 7 of them. The IC stated above will be screwed onto a heatsink to radiate heat out of it when it works.
If all soldering point are fine, come towards the IC legs and measure the voltages at each leg. The voltages must be
pin 1= Ground
pin 2= 12.6
pin 3= 24.7
pin 4= 4.4
pin 5= 4.4
pin 6= 24v [vcc]
pin 7= 1.8
All voltages stated above are DC voltages with respect to ground. If any of this voltage is missing, find out the reason for that. If all of them are noted abnormal, IC may be defective, and replace it.
[vcc] stands for main input voltage to the IC.
If you need any more assistance, feel free to contact me through Fixya. Ok.
Dec 07, 2010 | Panasonic TC-21Z88R 21" TV
I have a Tedelex Ec Rp 4389 Rear Projection with a convergence problem i replaced ic(stk392-560)with(stk392-570) and it is still the same i noticed that pin 10 of the ic only gets 4.5v is that normal
Pin 10 should be at the positive convergence power voltage. The ICs run on a plus and minus voltage from a power supply. Usually +/- 15V to +/- 30V. (don't know this brand.) (not sure if -570 is replacement for -560; could be.) I'd look through main power supply for these 2 voltages. Ohm to pin 10, etc. Check PS fuses there.
May 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Ic used in which section of philips TV kit
tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Oct 10, 2008 | Televison & Video
TV problem
Over Current Protection
Pin 1 of IC951 is also the Over Current Protect input.
The internal FET.s ground return is at pin 2 of
the IC. The voltage drop across R955 and R956
indicates the FET.s current, and is coupled through
R953 to pin 1 of the IC. The Over Current Protect
circuit is activated if the voltage at pin 1 of the IC
exceeds 1.35 volts.
Stabilization and rough regulation are provided by
feedback from pin 3 of T951 to pin 1 of the IC. Fine
regulation feedback is from a secondary supply,
through the Photo Coupler, PC951, to pin 1 of IC951.
Its possible that Diode D953 is leaky allowing the voltage to rise on pin 1 of the IC
Feb 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
